2 Q's Brakes and Steering...
Rallyman Jun 21, 2011
  1. Rallyman
    Rallyman LPG Abuser & have VAGCOM Bronze Supporter
    222
    2 Quick questions,
    I recently got the dreaded ABS light with 01203 fault code, due to work & family commitments, I am not going to get a chance to do a DIY repair on the ABS module... :-( I have done a search around, can anyone recommend an outfit to refurb my module - I have seen some on ebay, around 100 quid - is that the going rate????
    My PAS fluid has seen better days..... which type / brand does the audi run ?
    Many thanks.....
    Michael
  2. aragorn
    18,612
    872
    PAS fluid is called "CHF11S" you MUST get that type or you'll break the rack.
  3. Rallyman
    222
    Is this fluid generally available, or stealer only ?
    Aragorn - Are you running lpg ?
  4. aragorn
    18,612
    872
    No its pretty readily available, i got a few litres of it from my local factors, branded Comma.
    Not running LPG either, just super unleaded.
