2 bikes and an 8v s3?
SockToy Apr 23, 2014
  1. SockToy
    SockToy Active Member
    109
    29
    Dealer just called me to say audi bike rack requires a towbar ... And that'll be another 400 to fit. Agh. Anyone out there found a good, paintwork safe, way of transporting 2 bikes on a 3 door? No roof rails...
    Matt
  2. 0B1001001
    0B1001001 Well-Known Member Team Monsoon Audi S3
    451
    278
    AFAIK, towbar is not an option on S3!
  3. The Challinor
    The Challinor Well-Known Member Audi S3
    4,322
    1,100
    I think it's in the accessory catalog and not in the main brochure.
  4. PilotAudi
    PilotAudi New Member
    2,352
    479
    It isn't... not type approved and issues with exhaust apparently. You can probably get a retrofit on roof rails, it was possible locally with 8P versions.
    The Integrated roof rails are so much more secure than the conventional 'roof rack' style
  5. moffe
    moffe Active Member
    162
    91
    You don't need to have roof rails to have roof bars...
    I don't have roof rails, because I didn't like how they look on the car, too short. :) But I have Thules roof bars when needed to have something on the roof.
  6. The Challinor
    4,322
    1,100
    Presume all A3's and S3's have the anchor points then.
  7. SockToy
    109
    29
    S3 3door can't get integral rails. Thule roof bars then?
  8. moffe
    moffe Active Member
    162
    91
    Don't know about the Thule roof bars on the 3 door version... Maybe, maybe not. Sportback they will fit at least. But I would check if you have the "holes" :)
    But I guess there will be no hole in the back, because of the missing door. :D
    See picture:
    EDIT:
    When thinking about it, I wonder how would you actually attach Roof Bar in the back?? Could be that its not possible at all to have any roof bars in the 3 door version. But I would raise the question to the dealer!
  9. warren_S5
    warren_S5 Moderator Staff Member Moderator VCDS Map User
    7,210
    2,483
    Saris Bones?
    I'm thinking about trying one as I hate mounting bikes on roof racks. Only issue is you may have to get an additional lighting board / number plate if the set up obscures your car too much.
  10. PilotAudi
    2,352
    479
    This should work on 3dr. If it's anything like 3 dr Golf you have to gently prise back rubbers.
    Thule Rapid System 754
    Thule WingBar 969
    Kit 1708 Rapid
    Just sold my 754 (from A7).
    Bar size is the recommended size but others fit. Just make sure they don't stick out too far or you could be in trouble!
  11. Itguy
    Itguy Well-Known Member
    1,130
    449
    I've got the thule roof bars for my sportback without rails and the instructions do refer to fitting on a 3dr too so yes, they will work.
    Rock solid too, no problem at all.
    SockToy likes this.
  12. SockToy
    109
    29
    Thanks ltguy ... Do you have a model number?
  13. PilotAudi
    2,352
    479
    Thule Numbers in my post above. Foot pack listed is for 3dr.
    SockToy likes this.
  14. SockToy
    109
    29
    Perfect!
  15. Not sure about S3 but I got a Westfalia detachable towbar on my A4 for £250 plus £70 to fit it.
