2.8 valve cover gaskets
205man Apr 27, 2010
  1. 205man
    205man Active Member
    1,072
    14
    my 2.8 quattro has just started to develop a small oil leak from the valve cover gaskets, where apart from main dealer would be best place to get some replacements from.
    and any idea how much they roughly to be and how hard a job is it to do?
    alan
  2. phoenixv6quattro
    phoenixv6quattro staylowmovefast
    1,396
    Not hard to do. I bought mine from the stealers as they are inexpensive.
  3. Audidave
    Audidave Member
    60
    just replaced my rockercover gasket on passenger side but oil smoke still rising from manifold after a run. have also replaced all the breathers, anything else that leaks on back of rocker cover?
  4. phoenixv6quattro
    1,396
    The root of the problem is probably fixed. What could be happening (and what happened on mine when I replaced the gasket) is the old oil is still dripping onto the manifold. Give the general area a good spraying of de-greaser then jetwash the area/engine and see if it still does it. Failing that there is the cam chain tensioner gasket (half moon shaped) in the same location. I reckon I good clean should cure it though.....Good luck!
