2.8 - s4 suspension
205man May 6, 2010
  1. 205man
    205man Active Member
    1,072
    14
    is there any difference between the dampers/stuts fitted to the s4 and the 2.8qs (1999)?
    i may have the chance of getting a set and i was going to put them on my 2.8q sport as i have a leaking rear damper and they would do me til i can afford a set of coilovers
    alan
  2. aragorn
    18,437
    845
    Dampers are more or less the same. Probably slightly stiffer valving but thats only a good thing.
    rear springs should work, fronts might be a bit heavy.
  3. 205man
    1,072
    14
    not worried about the springs as ill use my original sport ones it was just the dampers/struts that i was wondering about,
    thanks for that
