2.5tdi won't rev above 3500rpm?!?
pdf11 Jan 7, 2012
  1. pdf11
    pdf11 New Member
    17
    hi.
    i have a 1999 2.5tdi a4 avant that wont rev above 3500rpm, and isn't that quick getting there. doesnt feel like its in any kind of limp mode, but its as if its 'limited'?. i've unclipped the maf sensor and still no difference. it starts and sounds smooth as it should.
    could anyone shed some light on this as i've run out of ideas
    cheers
  2. Bradderz_1988
    3,958
    238
    Try blocking off the EGR valve see how that helps it !
  3. Bradderz_1988
    3,958
    238
    Also try cleaning the maf sensor with brake cleaner.
  4. pdf11
    pdf11 New Member
    17
    i've just seen a egr blanking plate on ebay, i'm ordering one and let you know
    thanks for the quick reply
    cheers
  5. PAULF
    PAULF Active Member VCDS Map User
    712
    66
  6. pdf11
    pdf11 New Member
    17
    Right.....cleaned maf sensor, de-coked turbo vanes with mr muscle, and blocked off egr valve. 1st and 2nd gear rev fine, but only to 3500rpm. 3rd - 6th still not quick, doesnt seem to be a limp mode just feels lazy getting there compared to 1st and 2nd, but still only revs to 3500, wont go past....running out of ideas as the engine runs sweet as a nut, starts fine, but at the moment its like theres a limiter on it?
    any help would be greatly appreciated....
    cheers
  7. PAULF
    712
    66
    How about looking for air bubbles in the clear fuel line?
    The fuel filter can leak air at the tee-piece, which would be worse under high revs.
  8. aragorn
    18,441
    845
    Does it rev past 3500rpm in neutral?
  9. pdf11
    pdf11 New Member
    17
    thanks for the replys. i'll try both suggestions tomorrow....keep you posted
    cheers
  10. pdf11
    pdf11 New Member
    17
    hello again!!!
    just an update....
    checked for air bubbles at tee-piece, i presume thats the part that clips on top of the fuel filter, no bubbles seen after observing for a while, and the car revs to red line in neutral but not in gear, still only 3500. did a trip at weekend at a steady 70-75 and returned 35mpg, doesnt seem too bad, is this reasonable? still doesnt feel quick in 3,4,5,6. the mrs leon 110 tdi is a lot quiker, she's very competitive and is now taking the micky out of my beloved 2.5!!!! lol
    any others ideas?....
  11. S4_dan
    S4_dan Fire up the Quattro! VCDS Map User
    2,715
    162
    have you tried to Scan it with vag-com and see what is coming up?
  12. murran
    murran Well-Known Member
    1,545
    39
    revs round the revs in neutral but not under load......... is the advance/retard working in the fuel rotary pump? you need to get it on the diagnostics to check it.
  13. pick master
    pick master New Member
    Hi thanks for your assistance by PMs
    i had a look at cat and mine was clogged up so cut out and now it pull like a train :)
    i drilled a small hole in front and looked in with enderscope then cut pipe before and after cat and fitted a section of pipe
    i might need to find a cat for MOT
    regards Andy
