2.5tdi v6 avant engine issue (00575)
dualmono21 May 16, 2013
  1. dualmono21
    dualmono21 Well-Known Member VCDS Map User
    1,134
    a friend of mine has just bought a one owner 1997 2.5 tdi avant
    for the most part it is in very good condition , however after checking it over today ive noticed a couple of minor problems i can hopefully sort out with a little help
    im getting the 00575 vcds code come up when i scan the car
    firstly for not making enough boost pressure then after clearing and retrying for making too much boost pressure
    both of these are linked to the n75 valve
    this part has been superceeded a long time ago , what i would like to know is if i can fit a newer n75 off
    something like a seat leon cupra
    has anyone done anything similar to this ?
    the other problem i have noticed is the brake servo master cylinder appears to have been repaired at one time or another
    but unfortunatly this too has failed again
    is it possible to change just the clear plastic level indicator chamber or do you have to replace the entire unit
    many thanks
    nath
  2. PAULF
    PAULF Active Member VCDS Map User
    712
    66
    For the boost problem, you need VCDS to test the N75 valve.
    Go to Basic settings, block 11 (IIRC) and with the engine running, it will cycle between actuator full up and full down.
    If you do not have VCDS, with the engine off, the turbo actuator arm should be away from the stop. When the engine starts it should pull the actuator to the stop.
    Try moving the actuator by hand - if it is sticky or restricted, go to the Mr Muscle Turbo clean thread on here.
    Another common fault is the hose to and from the actuator/valve/vacuum pump leaking/perishing.
    As for getting a different valve - why would you? It's a modulating valve so it is the control of it (ECU) that makes the difference, not the valve.
    Your brake reservoir can be changed on its own. Just pull it off. You do not have to bleed the system after changing it.
    When you next have a brake repair, be careful when using a pressure bleeder or you will be dong it again - they are prone to popping it seems, as a few of us on here have found this out the hard way!
  3. dualmono21
    1,134
    thanks for the reply
    ive been lead to believe inside the valve the seal can perish and this can cause running problems
    ill have another look at everything tommorow
    thanks again
    nath
  4. dualmono21
    1,134
    have got the car on vcds now paul
    the measurements are slightly differnat for the n75 valve depending on which you use
    at idle the car is showing 90.3 duty cycle and goes down as you rev the car in the measuring block section 11
    in the settings section 11 the car cycles between just over 100% and 0% on the n75 valve (the only other thing i notice here is the maf reading goes through the roof )
    the duty cycle of the egr is only at 15% when at idle but according to vcds should be 40-75%
    maf actual is reading high at 329 mg/str
  5. dualmono21
    1,134
    the full code im getting from vcds is 00575-11-10 .... control limit not reached intermittant
  6. aragorn
    18,036
    725
    Check all the vacuum pipes and look for splits or perished bits.
    Check the movement of the VNT shaft.
  7. dualmono21
    1,134
    ive checked the vacuum pipes and they appear to be working o.k as when you remove them you can feel the pipe sucking air
    ive sprayed some wd40 on the actuator shaft and it does now appear to move a little more
    the car is now not giving me a fault code but is still absoloubtedly flat as a fart , the turbo is definately spinning as its getting hot
    but i just cant feel it providing much boost and the engine is reluctant to rev beyond 3000rpm when you put your foot flat to the floor
  8. adamss24
    adamss24 Well-Known Member
    4,561
    395
    Change MAF...
  9. dualmono21
    1,134
    im gonna take the car out tommorow and do some logging off the measuring blocks to see what the car is doing under load
  10. PAULF
    712
    66
    It does sound as if your vanes are sooted.
    With the engine off, the actuator should be away from its stop (fully down). When you start the car, the actuator should smoothly go up to the stop.
    If it doesn't move up, check to see if it is jammed, if not then look for vacuum leaks.
    If no leaks, then suspect the N75 valve.
    Once it is moving up ok, move on.
    Now go to ENGINE, BASIC SETTINGS on VCDS, and I think it is in block 11 - you'll have to check.
    The car will then cycle the N75 fully open and closed every 10 seconds.
    The actuator should move up and down smoothly full range.
    If not, then Mr Muscle it.
    If it does move up and down, try moving it by hand to see if you feel any grittiness/hardness caused by carbon in the vane rollers.
    If you suspect this, Mr Muscle it.
    Do a logging run to check for overboost.
    If you have a look here 2.5TDi Sluggish you might get clues on the logging (at the end).Read my graphs, and if you have a max 'dump' signal combined with an overboost, Mr Muscle it and check again.
    Once the actuator is confirmed moving correctly, then think about MAF sensor, rod length or stop screw settings.
