2.5tdi rocker cover gasket - any other stuff at the same time?
haytch75 Apr 14, 2012
  1. haytch75
    haytch75 Member
    176
    17
    I'm having a rocker cover gasket replaced next week (AKE engine). Question is......is there any other preventative maintenance I can have done at the same time?
    I'm getting my local Indy to do it but wondered if you guys knew of anything else I could get done whilst he's in there and got the pipes off?
    Thanks in advance.
  2. quattrojames
    14,068
    585
    I'm getting mine done too soon. The only thing that springs to mind is replacing the return pipes off the injectors. These can perish and suck air in.
  3. Turkster
    Turkster Bro.Paul 2.5TDI Quattro Sport
    2,811
    54
    the return pipes and the brass washers that sit in the return pipe bases.
  4. haytch75
    haytch75 Member
    176
    17
    cheers fella's.
    I'll look into getting these done......do you have much idea how much the parts cost?
  5. PAULF
    PAULF Active Member VCDS Map User
    712
    66
    I did my AFB engine which should be similar to your AKE, and the washers were pennies from Audi- remember you need 12 in total. The pipe I got from a factors and cut to the correct sizes.
