2.5tdi oil leak around alternator
white.akita Sep 15, 2013
  1. white.akita
    white.akita Active Member
    322
    30
    Hi everyone, yesterday I bought a 2003 a4 2.5tdi quattro with a oil leak that seems to be coming from behind or above the alternator which is covered in oil.
    anyone know where the leak is likely to be coming from ?
  2. AudiLeon
    AudiLeon Well-Known Member VCDS Map User
    2,244
    185
    Probably the rocker covers.
  3. white.akita
    322
    30
    They look dry as a bone but its hard to see 100%
  4. white.akita
    322
    30
    Any advice on being able to stop the leak or finding it without taking the front end of the car off ?
    Might try some of that engine stop leak fluid.
  5. AudiLeon
    2,244
    185
    Nooo don't use that.
  6. white.akita
    322
    30
    after some more reading it seems it could be the cam seal leaking
  7. quattrojames
    14,050
    578
    You mean rocker covers? Mine weeped slightly and the oil went everywhere!
  8. white.akita
    322
    30
    no, I have read that it could be a camshaft seal when the alternator is covered in oil.
  9. AlexGSi2000
    AlexGSi2000 Well-Known Member VCDS Map User
    1,464
    199
    Yeah, more than likely your cam seal - mines doing the same. :(
  10. Turkster
    Turkster Bro.Paul 2.5TDI Quattro Sport
    2,800
    50
    why not use the stop oil leak stuff ?
  11. AlexGSi2000
    1,464
    199
    I would never dream of using it to be honest. From what I have heard it can block small oil channels, clog oil pick-ups.etc
    Which can lead to bigger problems.
  12. S4_dan
    S4_dan Fire up the Quattro! VCDS Map User
    2,722
    162
    As above, it's great in a cheap old banger but not in a Audi. It can cause blockages. All it does is thicken up the oil and soften the seals. It's not a permanent repair.
    Same with Radweld.....fix the leak properly rather than boding it!
  13. white.akita
    322
    30
    How would it block ?
    All the ones I have seen are just like water.
  14. white.akita
    322
    30
  15. AlexGSi2000
    1,464
    199
    Yeah, but when mixed with oil it thickens up.
    There are loads of very small oil channels - especially around the hydraulic lifters, if oil flow is reduced even slightly below spec it can cause accelerated wear.
    As Dan said, its fine for a banger you don't care much about, but modern engines run low tolerances - so even thickening the oil slightly could be devastating.
    My cam oil seal is weeping oil too - as I have exactly the same symptoms - im holding off til the cambelt needs doing again, unless it kills another alternator.
  16. t3pkd
    t3pkd New Member
    I had a bit of a leak on mine oil everywhere underneath turned out to be oil filter seal leaked into v and went everywhere replaced cleaned no more leak
  17. wesmaster
    wesmaster Member
    300
    20
    I had the oil filter I ring leak too, new filter and oil change of course, all done!
