2.5TDi Injector Grommet / Seal
AlexGSi2000 May 30, 2013
  1. AlexGSi2000
    AlexGSi2000 Well-Known Member VCDS Map User
    1,464
    199
    Does anyone know where to source new grommet's / seals for the fuel injectors on the 2.5TDi?
    The seals are the ones on the rocker cover where the injector passes through.
    Many thanks!
    Alex.
  2. swarcup
    swarcup Well-Known Member
    1,326
    40
    as far as i know they are part of the rocker cover itself, not sure if they are available seperately
  3. PAULF
    PAULF Active Member VCDS Map User
    712
    66
    I wasn't able to find them either- I had to buy the whole rocker cover :sob:
  4. AlexGSi2000
    1,464
    199
    Great - out of interest, how much was it?
  5. madmike01uk
    madmike01uk Member
    430
    21
  6. Az
    Az Hard slammed!
    1,023
    35
    I need to replace the left bank cam cover gasket on my car due to a slight oil leak, and whilst I'm at it I'll replace the injector seals as well, Audi quoted me for the cam cover gasket on its own and for 6 injector seals (2 per injector) so they must be available separately. I'm away this week so can't help you with the part numbers or price of them as I've left the part/price enquiry from them at home.
  7. adamss24
    adamss24 Well-Known Member
    4,584
    407
    The injector's copper seals are different of the cam rocker seals for the injectors and only available as part of the rocker cover...
  8. Az
    Az Hard slammed!
    1,023
    35
    Right ok, so if I'm having to replace the cam cover gasket due to an oil leak am I going to need (or is it advised) to replace these copper seals for the injectors at the same time? Does the cam cover gasket kit come with other injector seals then? And would it of been the copper seals that Audi quoted me for?
