2.5TDi glow plug problem
mmarks Feb 29, 2004
  1. mmarks
    mmarks New Member
    Hi there,
    I know I've asked this before but I am desperate for some guidance!
    A6 quattro estate with 2.5Tdi (5 cyl) engine I think code AEL.
    Glow plug light comes on & goes out after a few seconds, takes longer when really cold so seems to be working. But no power gets to glow plugs. If I connect glow plug directly to battery it glows, If I turn on ignition it receives no power (proven by unscrewing glow plug & earthing against engine block).
    where do I look - relay, fuse etc.
  2. Major_Ingram
    Major_Ingram New Member
    It sounds like you have a glow plug controller unit failure.
    I don't know where it is situated on your car but following the heavy cable from the glowplug back should give you a clue.
    Hopefully it'll just be a fuse that has gone!
