2.5tdi avant in tank fuel pump equivalent part number....if there is one!!
pdf11 Oct 25, 2011
  1. pdf11
    pdf11 New Member
    17
    hi all.
    looking for some help locating an equivalent part number. I have a '99 B5 2.5tdi avant with a dead in tank fuel pump. Theres quite a few about on ebay but none with the part number '8D0 201 319B'
    Is there a similiar part i could use or adapt?
    cheers
  2. aragorn
    18,129
    763
    That part number isnt listed as a pump.
    Looks like its the cap that the fuel pipes attach to. The diagram also doesnt show any in tank pump attached to that part, looks like a swirl pot and nothing else.
    AFAIK these engines dont have electric lift pumps, the IP on the engine does the sucking.
  3. adamss24
    adamss24 Well-Known Member
    4,578
    402
    Most likely your injector pump is dead, the in tank pump is only there to keep the baffle full of fuel so the Vp44 pump does not cavitate.
  4. pdf11
    pdf11 New Member
    17
    managed to find one. thanks for the help. had the injector pump recon'd in april. it is a swirl pot, theres a live feed to the tank but no motor 'swirling'. managed to locate a complete swirl and sender for £29.....just hope it works!! lol
