2.5 V6 TDI Strange issue after cambelt change
wesmaster May 29, 2013
  1. wesmaster
    wesmaster Member
    300
    20
    Hi, this is a strange one, A6 allroad auto in for cambelt/wpump/thermostat, all goes ok. Car comes backwith following fault: every now and again ABS ans Traction light oh and air suspension fault. Cant work it out.... vcds says check faults on other ecus, injection is slightly advanced, I knew that, did throw a code. Turns out that because the inj timing was 3 degrees too advanced the engine ecu put faults in 3 other ecus and put into limp mode. Set inj timing to perfect and runs like a dream.
  2. adamss24
    adamss24 Well-Known Member
    4,584
    406
    I think you will find the fault will re-occur shortly ! If the timing is within spec then the car is ok, i suspect faulty N75, dirty fuel filter or a combination of all 3 above...
  3. wesmaster
    wesmaster Member
    300
    20
    Cheers Chris, spoke with him today, said it is running well. fingers crossed.
  4. adamss24
    4,584
    406
    Has he taken it to high speeds on motorway ? That's when it really happening....
