2.5 V6 TDI Quattro Mods??
ruffrida Jan 16, 2014
  1. ruffrida
    ruffrida Well-Known Member
    1,926
    313
    Afternoon All,
    Soon i will be the proud owner of a 2004 2.5 v6 tdi Quattro Estate.
    As the car is completely standard i wondered where the best place to start when it comes to mods, of course the coilovers, and a re-map have already been ordered, but where to go from here?????
    Also is the anything i need to be looking out for??
  2. S4_dan
    S4_dan Fire up the Quattro! VCDS Map User
    2,713
    162
    Good choice of motor. Is it a Sport or SE model?
    I'd hold off on the remap for now, speak to Adamss24 about different turbo option and even injector nozzles (depends on how far you want tune) and then remap it all in.
    RS4 rarb is a good mod to add to improve handling. A lot people say don't use the cheap (sub £400/500) coilovers as they don't work too well. I wouldn't know personally.
    Then it's subtle mods like led interior lights, number plate lights, alloys etc etc.
    Dan
  3. ruffrida
    1,926
    313
  4. Mike.M
    Mike.M Well-Known Member
    2,508
    169
    Full DIS, cruise control, puddle lights, arm rest, RS4 rear ARB, 312mm brakes if not already on,
  5. S4_dan
    2,713
    162
  6. ruffrida
    1,926
    313
    Already got Cruise & Arm rest,
    Puddle ligths Defo (loved em on me 8L)
    Full DIS Unsure as may chaneg to a non standard HU!
    Defo RS4 rear ARB
    Will check the brakes
    Cheers Mike
  7. ruffrida
    1,926
    313
    Cheers Dan, Had seen that thread and got a bit worried, was even more tempted go the Shock & Spring way as me mate put coils on his EK4 civic and it was a dog until he went back to a the norm!!
    I have PM'd Chris so will see, cheers
  8. quattrojames
    14,050
    577
    That shouldn't affect it.
  9. ruffrida
    1,926
    313
    Tell me more?
  10. quattrojames
    14,050
    577
    Not much more to tell! The DIS info is displayed in the centre part of the dash as you know, and not affected by the head unit. If you change to an aftermarket head unit then (to the best of my knowledge) you will lose the radio display on the DIS.
  11. swarcup
    swarcup Well-Known Member
    1,326
    40
    Should be 312 front brakes already. Mine is. Check out my signature for a few mods
  12. quattrojames
    14,050
    577
    If they're not then there's been a theft!
  13. ruffrida
    1,926
    313
    Nice 1 guys, see the is plenty of cosmetic mods, but is the any simple engine mods that can be done??
  14. haytch75
    haytch75 Member
    176
    17
    Block off the EGR?
  15. ruffrida
    1,926
    313
    Please tell me if iam wrong here but the simple things then;
    EGR Delete / Block
    Induction Kit,
    De Cat
    Nozzles?? (which ones)
  16. AlexGSi2000
    AlexGSi2000 Well-Known Member VCDS Map User
    1,464
    199
    EGR can be blanked using a plate from ebay - think I pad about £5 for mine.
    Personally I wouldn't bother with an induction kit, the standard one has a cold feed and is good for high power I believe, just swap the filter over for a foam one.
    Dont think there are any aftermarket de-cat pipes, the 2.5 has 3 IIRC (a pre-cat off the turbo - you can smash the innards out of it) and two underneath. I paid a local company (St Helens) for a full stainless system - it was only £450.
    Nozzles, I think are Bosio 683 - but Adamss24 is the man to speak to about these!
  17. ruffrida
    1,926
    313
    Emailed him but had no response as of yet!
  18. AlexGSi2000
    1,464
    199
  19. ruffrida
    1,926
    313
    Nice 1 !!
    Have you gone for Nozzles? Seem be hard to get hold of!!
  20. Jimmy TDI
    Jimmy TDI Pro Tinkerer Audi A4 Audi Avant Owner Group TDi
    1,320
    262
    Don't bother with induction kits on diesels they're a complete waste of time. If you can get more cold air to the box then that will help, but there is absolutely no gain from fitting a performance panel filter over the standard paper filter.
    Chrismawa likes this.
  21. archemist
    archemist Active Member VCDS Map User Audi S3 Team Brilliant Black
    247
    31
    RNS-E mkII :sex:
    if you want factory look not fast n furious
  22. ruffrida
    1,926
    313
    Well the 1 i found turned out to be a bit of a dog, so didnt bother.
    Of the back of this, i have come across a 2.5 (163) Tdi, now it says quattro on the back the lad said it is not permanent 4wd, anybody give me any clues on this, as i have never heard of these before, as i thought all the quattros were permanent 4wd???????????
  23. SmoothAssault
    SmoothAssault Will design for mods
    822
    53
    Yea, they're all permanent 4wd. Sounds like he doesn't know what he's selling, or worse, he does and he's trying to sell you a fwd with a 99p quattro badge on the back?
  24. ruffrida
    1,926
    313
    My mate seems to think it is the same system they had on the A3's were it was fwd until needed, is this wrong??
  25. SmoothAssault
    822
    53
    My understanding was the B6 quattros were 4wd all the time. And one of the last models to split the power 50/50 front to back rather than favouring the rear as some of the newer models do.
    Let others come along to confirm, but this is what I was always lead to believe.
    Defintely feels as though it's always 4wd when driving it about.
    m40rcd likes this.
  26. IanFM
    IanFM Active Member quattro Audi A5 TDi
    452
    81
    You are gonna cause a riot with comments like that lol. The A3 has a haldex quattro system which is electronic and does front wheel drive with rears as required and the controller is renowned for dying whereas all A4 quattros are permanent mechanical 4 wheel drive!
  27. haytch75
    haytch75 Member
    176
    17
    All B6 quattro's are permanent 50/50 4wd but I thought all 2.5tdi B6 quattro's were 180bhp?
  28. quattrojames
    14,050
    577
    All 2.5 TDi quattro's are 180bhp
    If it's 163bhp then it's fwd...
    And yes, no Haldex was ever used in the B6 range. Ever. Despite what your mate says :thumbsup:
    PS, from memory the Torsen offers an (up to) 75:25 split?
  29. ruffrida
    1,926
    313
    Cheers James, didnt think it was right, will be having a good look underneath for a prop, no prop no 4wd??
  30. ruffrida
    1,926
    313
    Hahhah always love a good debate hahahah
  31. quattrojames
    14,050
    577
    Yes, it's a simple check. Just look for the rear diff and driveshafts.
  32. ruffrida
    1,926
    313
    Just spoke to him, still convinced its a 2003 A4 Tdi Sport (163) avant haldex, he defo aint got a clue lol
  33. quattrojames
    14,050
    577
    Are you hoping it's a 180 quattro or a 163 fwd?
  34. ruffrida
    1,926
    313
    Just a quattro would be nice!
    Just put the reg in an insurance web site and on the vehicle spec it has nothing about it been a quattro, like already said a badge dont make it a quattro, will know more when im under it lol
  35. Chrismawa
    Chrismawa Active Member
    457
    46
    True but insurance can get it wrong as mine keeps coming up as a TDI Quattro but it isnt so no idea why thats happened.
  36. adamss24
    adamss24 Well-Known Member
    4,584
    406
    As above, look underneath for diff and rear driveshafts. All quattro's were 180Bhp, they bloody need extra power with the extra weight ! Also early AKE engines are slightly different to the later BDH engines, early ones are euro3 and have larger injectors, later are euro4 and smaller injectors and more limiters in the maps. If you want to tune one then going for an early engine is definitely the way to go !
    Also early y and 51 reg had all alloy intercoolers so they can hold more boost without splitting. On stock hardware and a remap they will see 200-210 Bhp, add larger nozzles (BAU allroad are the largest stock fitted nozzles) and you're looking at an extra 10Bhp and 50Nm of torque.
    For proper gains you need to ditch the factory blower and get a modern hybrid in there and larger nozzles. Bosio pp683 are 20-40% larger but are designed for AFB-150Bhp injectors so you need to source a set of injectors for that. Going for silly power you will need larger nozzles (bosio race 683, doktores +60% or even the +130% 8 hole nozzles he's selling), ported heads, later BAU/BDG/BDH cam roller heads with solid cams (not entirely necessary but they have less cam gear loses compared to AFB/AKE/AKN/AYM engines), Sachs SRE clutch and a few more bits and bobs. That will make for a very nice driveable car with over 600Nm of torque and loads of midrange pull. Bhp is irrelevant as it's the torque that matters ! Mapping is the next big thing- very few tuners know how to tune these apart from a generic remap so thread carefully ! Adding a 3-4 Bar map sensor in the mix is also a wise move...
  37. ruffrida
    1,926
    313
    I have been mainly looking at 04plates,I take it these will all be euro4 then?
  38. adamss24
    4,584
    406
    ruffrida likes this.
  39. wheymonster
    wheymonster Member
    50
    Sorry for asking this but what are the pros and cons for this?
  40. Jimmy TDI
    1,320
    262
    Pros:
    No gunk clogging up the veins in the turbo
    Cleaner, cooler better burn
    Possible slight MPG gains
    Cons:
    Takes slightly longer to warm up in cold weather
    If your car is 53reg onwards you will get the EML light on. To get rid of it the EGR needs to be deleted from the map on the ECU.
    wheymonster likes this.
