2.5 V6 TDi Engine Oil
AlexGSi2000 Mar 9, 2012
  1. AlexGSi2000
    AlexGSi2000 Well-Known Member VCDS Map User
    1,461
    199
    Just after some advice on oil for these engines.
    Firstly, im taking it the 2.5 V6 TDi is a "PD" engine?
    On all my cars in the past I have serviced them myself, I will be doing the same with my A4 - I change the oil and filter every 6,000 miles religiously.
    When I purchased my Audi last month, the first thing I did was carry out an oil change - I used 0-30 Shell Helix Ultra Extra which complies with VW 504.00 / 507.00.
    Is this oil ok to use on this engine? (in the past on the service receips 501.01 has been used)
    If its ok then I will carry on using it - its just that I have heard horror stories with cams being chewed on PD engines.
    Thanks!
  2. quattrojames
    14,045
    570
    It's not a PD engine no.
    The spec is listed in the manual, I can't remember what it is off the top of my head.
  3. AudiLeon
    AudiLeon Well-Known Member VCDS Map User
    2,169
    148
    As above.
    But I either use castrol Edge or genuine vag long life oil.
  4. adamss24
    adamss24 Well-Known Member
    4,550
    392
    Use a 5w40 oil as the longlife oil is too thin ! Drop it every year/6k and you'll have no issues whatsoever !
  5. Turkster
    Turkster Bro.Paul 2.5TDI Quattro Sport
    2,797
    47
    so would you advise against the long life 2 year service that audi offer? i was thinking the long life service was the better type? also how many Ltrs of oil does it take?
  6. AlexGSi2000
    1,461
    199
    Which oil do you use mate?
