2.5 tdi v6 Quattro avant water temp sensor.
Keggers Nov 4, 2013
  1. Keggers
    Keggers Member
    77
    Could anyone advise where to get a new sensor for my motor. It looks like it has a green cap on the end of it. Is it a straight forward job to replace it?
    Thankyou.
  2. myth
    myth Member
    155
    From any auto shop?!
    Yes, it's very straight forward. If you do this job when engine is cold, just unplug the connector, take the clip out and pull the sensor. If you it when engine is hot, just uncap the expansion cap (to release the pressure) and put it back on and then do as instructed above.
  3. Keggers
    Keggers Member
    77
  4. adamss24
    adamss24 Well-Known Member
    4,584
    405
    Get a new seal as well. I would only fit a genuine CTS, cheaper ones does not seem to last...I do suspect the thermostat is blocked'stuck open though, not a easy job to sort on the good old v6 engine...
  5. Keggers
    Keggers Member
    77
    How would I know if it is blocked and stuck open?
  6. Keggers
    Keggers Member
    77
    Will I lose any coolant while replacing this part?
  7. Keggers
    Keggers Member
    77
    Hi there again, new sensor fitted, coolant topped up, took it out for a run and temperature steady at 90 which is Center on my display needle. Can I assume this is all ok? Does this mean my thermostat is ok and not stuck open?
    Cheers.
  8. myth
    myth Member
    155
    Your assumption is correct.
