2.5 TDI Turbo Question
hodgy0_2 Oct 7, 2013
  1. hodgy0_2
    hodgy0_2 Member
    97
    Hi
    I think the turbo on my Quattro 2.5TDI is on the way out -- I can deffo hear a "new" noise, slightly higher pitch
    anyway, what model is it -- a quick glance on Ebay seems to suggest it is a Garret T3 and lots for sale - is that correct?
    does anyone know the exact model number (I have a MY2002)
    also has anyone fitted one, any gotchas special tools etc
    thanks in advanced
  2. gtiboy
    gtiboy Member
    144
    3 bolts on the heat shield
    3 bolts on the hot side attaching it to the pre cat.
    Jubilee clip on the air side (if i Rember correctly )
    4 bolts attaching iot at the base be carefull as you dont want to round them of as i did with one ( causing no end of problems )
    I did my own when it went and once i took the heat shield off it was relativly straight forward .
    I just had a problem with the setting up so had to get adamss24 to sort it out properly as the boost was lacking when going up steady inclines .
    mines a A6 2.5tdi AKE so may be diferent and alittle more spacious under the bonnet if yours is a A4 ?
    Wd40 or heat gun at the ready.
    Read it for codes first though to save costs if not needed ?
    Or try the Mr Muscles idea ?( google or search on this site )
    Good Luck
  3. hodgy0_2
    hodgy0_2 Member
    97
    thanks GTIboy
    mine already lacks a bit of boost when on a steady inclinec - LOL
    and I have tried the Mr Muscle trick
    it still drives fine TBH (really well, apart from the odd boost issue), but I just think the Turbo is on the way out, it has done 165K
  4. adamss24
    adamss24 Well-Known Member
    4,557
    394
    The turbo is a gt2052v and whilst widely available there are a few different versions fitted to different power variants. If you need i have a good one off a a6 tdi quattro sport, drop me a pm if interested !
  5. gtiboy
    gtiboy Member
    144
    Adamms is your man .
    Well worth the long drive to go see him
  6. adamss24
    4,557
    394
    Thanks Satty, i do my best mate to look after people ! Cheers !
