2.5 TDI timing - how often should this be checked / adjusted?
JasonS Jul 10, 2013
  1. JasonS
    JasonS Member VCDS Map User
    124
    My A4 Cab is on 122k, the timing belt is due at 140k.. I'm about to change the oil, should I check the diesel pump timing as well?
  2. quattrojames
    14,050
    576
    Can you check it FOC? If not I wouldn't bother as it will be upset when you have the timing belt done anyway, unless you've any reason to think it's out.
  3. JasonS
    124
    I'm changing the oil myself and I have VCDS so can do the check..
    I'm just not sure if it's necessary - I've heard that the timing drifts a bit as the belts stretch, but I don't know if it's worth worrying about and I'll only make it worse if I try tinkering with it.
