Chrisavant
I have cured the jerky take-off and "parrot squawk" from my Multitronic! Many thanks to all the many contributors who helped me.
I'm the bloke who'se had THREE multitronics in my A4 Avant 2.5 TDi. The latest one started to jerk and squawk at about 1400 revs, after doing only 20,000 from replacement. Audi said nothing to do with Multitronic - transmission was overloaded because turbo overboosting giving too much torque, so internal clutches slipping giving "squawk". Independant VAG technician with Vagcom or similar said no overboost, so I was stuck.
Then, after advice from this forum, I spent the money and had the Multitronic oil changed at only 22,000 (rather than the 40,000 recommended) and insisted on the approved "double flush" oil change.
The result is a completely transformed driving experience. I have now done about 4,000 since the change and it seems a permanent improvement No jerk, no squawk.
The "double flush" technique is important but costly. 5 litres of oil is replaced, the engine is started, the Multitronic is exercised to open and close the clutches, and then the oil is dropped out and replaced again. In my case the original oil was very dark in colour, not clear like the new oil, indicating a lot of worn off clutch friction material in suspension.
But the effect is extraordinary. As someone else said, I don't see how a bit of oil can make so much difference. But this is no ordinary gearbox and has inside solenoid valves and multiplate wet clutches. My theory is that either the solenoid valves become gunged up with clutch debris and thus don't open and close as they should, or the clutch plates themselves become covered in a paste of dust and oil to form a sort of grease, which then causes them to slip causing jerking and squawking.
Either way it works and I would thoroughly recommend it to anyone with these symptoms. I had the oil change done by Audi as the Multitronic is still under warranty, although they wouldn't pay for the change as it was below the manufacturer's recommended interval and said it wasn't necessary! It cost about £220, but a lot better than the £4K they quoted to do turbo and manifolds, which I now think was a leg-pull.
Just to make certain, I am now going to have the turbo off and test bed checked by Midland Turbo at Nottingham (see sparate thread)
Many thanks to all. Chrisavant
