2.5 TDi Intermediate Pipes to Turbo: Gasket?
nedge2k Jul 3, 2014
  1. nedge2k
    nedge2k Member
    60
    It's been that long since I removed the exhaust manifolds, I can't remember if there's a gasket between the intermediate pipes and the turbo merge housing/elbow or not?
    Vagcat doesn't list one, elsawin says "not installed". Really!? I've never seen an exhaust system where a gasket or some form of sealing isn't used that close to the head. Especially pre-turbo!
    The 3.0 TDi engine has them, find it very odd the 2.5 doesn't?
  2. adamss24
    adamss24 Well-Known Member
    4,584
    405
    Can you post a picture of which are you're talking about as it's not that clear...
  3. nedge2k
    nedge2k Member
    60
  4. adamss24
    4,584
    405
    Yes, there are gaskets between collector and manifold pies... Try a different reg number from a newer car...
  5. nedge2k
    nedge2k Member
    60
    Bah, I know you're right because it would be madness not to have a gasket there.
    However, I just spoke to TPS and they mailed me a screenshot of their ETKA - still no gasket. I queried it with them - "doesn't have gaskets there"
    I've also checked other models/years on VAGCAT with the 2.5 and they all show the same thing - no gaskets.
    The annoying thing is, I really can't remember if the gaskets were there or not and worse, I seem to have kept every single other old gasket apart from them. Maybe they really aren't there?
    Luckily I have some exhaust gasket material, so worst case, I can make some.
  6. nedge2k
    nedge2k Member
    60
    Ha, TPS just told me to try "gasket sealant".
    I don't think even a VHT RTV would last long that close to the heads, especially pre-turbo. Exhaust putty would be gone in seconds.
  7. adamss24
    4,584
    405
    I am 110% sure there are gaskets there as i have took apart a few hundreds v6 tdi engines...
  8. nedge2k
    nedge2k Member
    60
    Guess I'll have to make some then!
  9. nedge2k
    nedge2k Member
    60
    Gasket material FTW...
    For anyone wondering, the hole cutter used was 44mm. Would have preferred 42mm but 44mm was all B&Q had :p
    Gasket material should be available from any local motor factor. I've used BGA RPK1 and it cuts very nicely with garden sheers ;)
  10. nedge2k
    nedge2k Member
    60
    That pic is off a listing on ebay. There are others on there that also show no gasket. My DIY gaskets have now failed which I can only assume is because there should not be a gasket there.
  11. adamss24
    4,584
    405
    There are no gaskets between the collector manifold and stainless pipes just between exhaust manifolds and flexi pipes... I must have miss understood which gaskets you meant...
  12. adamss24
    4,584
    405
    I never took off the heads like you did, the collector manifold and collector pipes does not need removing from the engine when you rebuilt it...
