2.5 TDI Bad Misfire AKE Engine Code
abyrne153 Sep 24, 2013
  1. abyrne153
    abyrne153 Member
    115
    2.5tdi Developed a severe misfire and almost complete power loss. Cruising along 70mph on motorway after 100 mile round trip and misfire began without warning. Limped home and found 2 fault codes;
    01268 Quantity Adjuster (N146) Defect Intermittent
    17583 Pre injection turned off P1175
    No water in fuel or anything obvious. Think maybe injection pump may be on the way out. Any thoughts on any other checks I could do would be appreciated before I take the pump off and send away for testing.
  2. Ian2012
    Ian2012 Active Member
    473
    29
    Dare i even mention camshaft wear
  3. adamss24
    adamss24 Well-Known Member
    4,578
    402
    faulty pump, i am surprised it's still running ! last one i worked with this faults did not start anymore...
    abyrne153 likes this.
  4. abyrne153
    abyrne153 Member
    115
    Thought as much Chris. Thanks again for your help. Just didn't want to take the pump off if there was anything else to try. It is starting and ticking over a bit lumpy but it is driving like a complete pig.
  5. Turkster
    Turkster Bro.Paul 2.5TDI Quattro Sport
    2,797
    47
    if i remeber rightly its the pumps ECU that is at fault and can be re programed,
  6. abyrne153
    abyrne153 Member
    115
    Thanks Turkster. You are right. The ecu on these pumps are a generally the source of the trouble. The soldered joints on the pcb break due to heat / cool cycling and this one has been repaired before. I took the cheap route a few years ago and sent just the ecu off for repair and although the car ran ok afterwards it was never perfect. It was smoky on startup when cold and the fumes were very strong on tick over. The pump should have been taken off and sent away to be calibrated/tested but I just never got around to getting it done. This time the pump is coming off and I am getting it done properly.
  7. abyrne153
    abyrne153 Member
    115
    I checked the cams a short time ago and they are in good condition.
