2.5 C5 Tdi A/c fan issues
wesmaster Aug 17, 2012
  1. wesmaster
    wesmaster Member
    300
    20
    Hi all, should the air con fan start running as soon as i turn on my A/c? The fan doesnt work at all, I know there are 2 speeds, but nothing happens.
    Anyone help?
    Can i force the fan to work with VCDS?
    Thanks.
    wesmaster
  2. wesmaster
    wesmaster Member
    300
    20
    All sorted, 40 amp fuse under dash blown. Works as it should. 😃
  3. ms1083
    ms1083 Member
    148
    Mine recently failed, its supposed to run all the time, worth checking the fuse? With mine the motor had burnt out making the fan very intermittant and never running very fast so I had to replace the entire fan - its quite pricey (£240) easy to replace without removing much, little screw on the top, twist fan then take it out, have to remove timing belt covers for access and the cables are annoying as they run below the viscous fan and then plug into the connector by the power steering fluid tank. with a bit of fiddilling it can be done without removing bumper or putting car in service position.
    Initally i removed the old one and realised the bolt that holds the blades in place was loose and after tightening it worked for 2 days, I think the bolt worked loose beucase it was failing & vibrating loads.
  4. A6willy
    A6willy New Member
    I also had this problem, fan was goosed kept blowing fuse! but the viscous helps loads anyway.
