2.0tfsi in the garage!
clarkiey Apr 9, 2013
  1. clarkiey
    clarkiey New Member
    So i've taken my 57 plate 2.0tfsi quattro feeling sluggish. Advice on here suggests it's most likely the diverter valve. Having spoken to technician working on the vehicle, he says it can't be, due to diagnostics showing boost pressures are fine. Could it still be the diverter valve or is he right? Cheers again!Clarkiey
  2. mmalh0151
    mmalh0151 Member
    170
    Valve is around £50 if I recall correctly.
    My S3 was very sluggish, fitted a forge DV and its like a super car now!! They are £199 or so though!
  3. phil76
    phil76 Active Member
    572
    40
    Ok i might be wrong here but surely reading the boost figures would only work when out driving in the car when the system is boosting up ? unless he went out in it ?,if he has done it while ticking over with diagnostic it wouldnt show anything
  4. S3AMK20VT
    S3AMK20VT Member
    169
  5. S3AMK20VT
    S3AMK20VT Member
    169
    what fault codes did it show?
  6. olethalb
    olethalb Active Member
    357
    76
    if boost levels are fine it would suggest not the DV
    i'l be looking at HPFP follower and pump drive lobe condition, again these can be measured on block 230 VCDS and view requested rail pressure vs actual
    this is all assuming the car has had regular servicing and coilpack recall done
  7. MrLapou
    MrLapou Well-Known Member
    1,233
    121
    Perhaps the MAF. Easy to check, with it unplugged... if the car drives the same then it's prob goosed...
    However when unplugging and starting engine it will pull a fault code, which will need vcds to reset.
    Keep us posted...
    Diverters can be had for a lot less...i.e. eBay item # 321101812754
  8. Bullys3
    Bullys3 Member
    191
    20
    That's the old revision with the rubber diaphragm need the revision D
