2.0TDI quattro (170) A3- Diagnostic error codes - EGR sensor bank P2080, P0544 - Help
murkins Jun 25, 2013
  1. murkins
    murkins Member
    61
    So my A3 2.0L TDI quattro (170 PS) has the engine management light on constantly and the glowplug light is occasionally flashing. I took it for diagnostics at Kwik-fit (the only people who could see me at the time) and it gave two codes.
    P2080
    P0544
    According to what I was told therse relate to sensor banks on the EGR valve.
    Also some reading onthe net shows this to be a problem with some VW Jettas.
    A few questions if you please...
    Anyone else had this problem?
    Can I just have the sensors replaced or does the whole EGR valve need replacing?
    What causes these failures?
    any idea on how much it should cost? (Kwik-Fit are quoting £254.14, D-tech in Sudbury wouldn't quote over the phone and I am too scared to get a quote from Audi :)
  2. @udi A3
    @udi A3 Site Sponsor Site Sponsor VCDS Map User
    1,819
    197
    I think you have EGT issues not EGR.
    Could also be DPF related if u have a DPF, would recomend scanning with VCDS and checking soot levels in the DPF at the same time.
    You will get a lot more info about the fault with VCDS than quick fit have told you.
  3. murkins
    murkins Member
    61
    Know anyone in Bury St Edmunds who will do that? :)
    Yeah, I know but I needed to have it checked ASAP as I didn't know what the problem was.
    Yep, EGT may be where the problem is alright. See this thread. This is why I need more info on EGT vs EGR. The guy at Kwik-Fit said that the EGR would need replacing, hence my question earlier.
    Incidentally, the guy at Kwik-fit didn't fill me with confidence as they need to call in a 'specialist' to do this work but I don't want them ordering a part I don't need only for that not to fix the problem :(
    Anyone else got any thoughts?
  4. @udi A3
    1,819
    197
    gen.heinz looks the most local and active user to yourself,
    VCDS (formerly VAG-COM) forum
    Ive pm'd you my number though incase you want this scan doing this evening and want to cover my fuel, wont cost me much as i stick to the speed limits and middle lane hog lol
