2.0Tdi Increasing engine Temperature - Information and solution
IceHanger Jul 27, 2012
  1. IceHanger
    IceHanger Active Member VCDS Map User
    340
    64
    Thought I share this with you guys, this came over from Part Info this morning, I thought it could be quiet usefull.
    IH
    [TABLE]
    [TR]
    [TD="align: center"]Technology in Focus
    Having trouble reading this email? View the web version[/TD]
    [/TR]
    [/TABLE]
    [TABLE]
    [TR]
    [TD][​IMG][/TD]
    [TD][​IMG][/TD]
    [TD][​IMG][/TD]
    [/TR]
    [TR]
    [TD="colspan: 2"][​IMG][/TD]
    [TD][​IMG][/TD]
    [/TR]
    [TR]
    [TD]Common problem, unusual cause
    Increasing engine temperature generally points towards a low level of engine coolant. However, an interesting case arose in the common VAG 2.0 TDI engine pointing to something completely different. Pierburg investigates…..[/TD]
    [TD][​IMG][/TD]
    [TD][​IMG][/TD]
    [/TR]
    [TR]
    [TD][​IMG][/TD]
    [/TR]
    [TR]
    [TD]Possible engine complaints:
    • Engine temperature increases
    • Engine warning light appears
    • “Shutdown shuddering” after turning of the engine
    The investigation:
    • Coolant levels were reviewed and appeared to be normal
    • Engine shuddering pointed towards the air supply system (e.g. air mass sensor, throttle body etc)
    • A diagnostic tool revealed the following fault code: P2102 - Throttle Actuator Control Motor Circuit
    • While there was a fault with the throttle body, it was not responsible for the engine overheating
    • Further investigation revealed that the throttle body and engine fan are protected by the same fuse
    • These complaints may be due to a defective or damaged throttle body
    [/TD]
    [TD][​IMG][/TD]
    [TD][​IMG][/TD]
    [/TR]
    [TR]
    [TD]The remedy:
    • Investigate the throttle body to see if this is stuck or contaminated with carbon or oil
    • If this is the case the throttle body is defective and must be replaced
    • If the fuse has blown, replace it and ensure this has the same amp rating as the one removed!
    Did you know?
    • In practice a number of different terms are used for throttle bodies such as:
      • Throttle valve
      • Diesel valve
      • Intake manifold throttle
      • Volkswagen would refer to it as an ‘intake manifold flap’
    The Range
    • Pierburg throttle bodies are used in more than 25 million vehicles making them one of the top suppliers of throttle bodies
    • The range is available same-day or next-day through FPS
    • For more information visit the F:Drive and Part Info websites or speak to your local FPS branch.
    [/TD]
    [TD][​IMG][/TD]
    [TD][​IMG][/TD]
    [/TR]
    [TR]
    [TD="colspan: 2"][TABLE="width: 608"]
    [TR]
    [TD][/TD]
    [TD][/TD]
    [TD][/TD]
    [/TR]
    [TR]
    [TD][/TD]
    [TD][/TD]
    [TD][​IMG][/TD]
    [/TR]
    [TR]
    [TD="width: 80%"]For Technical Bulletins, COSHH/MSDS sheets and technical information such as troubleshooting guides and videos, please visit www.partinfo.co.uk[/TD]
    [TD][/TD]
    [TD="width: 20%, align: center"][​IMG][/TD]
    [/TR]
    [/TABLE]
    [/TD]
    [TD][/TD]
    [/TR]
    [TR]
    [TD][​IMG][/TD]
    [/TR]
    [/TABLE]
    [TABLE="width: 600"]
    [TR]
    [TD="align: center"]Forward this email to a friend[/TD]
    [TD="align: center"]Download as PDF[/TD]
    [TD="align: center"]Unsubscribe from this mailing[/TD]
    [/TR]
    [/TABLE]
