2.0tdi 170 Timing Adjustment
BroomeyS3 Nov 28, 2013
  1. BroomeyS3
    BroomeyS3 Member
    39
    Hi,
    I've recently replaced the cambelt, tensioners and water pump on my A4. The timing is showing 4.46 torsion value on vagcom and needs to be between 0-1???. Can someone clarify that both camshaft sprockets need adjusting or is it just the right hand side one?
    Thanks.
  2. adamss24
    adamss24 Well-Known Member
    4,584
    406
    Did you use the locking tools ?
  3. BroomeyS3
    BroomeyS3 Member
    39
    yes I used the sealey locking kit VSE2358, the problem was the belt was slack going from the crankshaft to the water pump.
    I refitted the belt and tensioned it all up all working perfectly now. I was a bit worried as this was my first cambelt change so very pleased to have it all working as it should.
    I highly recommend doing it yourself.
    Tom
