2.0T FSI thermostat
Aidy06 Mar 25, 2013
  1. Aidy06
    Aidy06 Member VCDS Map User
    412
    19
    Hi, can anybody give me the OEM part number for the thermostat for a 2.0T FSI please? My temperature gauge takes ages to heat up and then just fluctuates between 70 and 90, I've looked for a thermostat but I've found 2 and they are both totally different. Thanks
  2. gen.heinz guderian
    gen.heinz guderian Well-Known Member
    1,346
    126
    If you are buying a Thermostat make sure you buy genuine from Audi/TPS . Give them your reg no to make sure its the right one.
  3. Aidy06
    412
    19
    I've seen 3 different ones that come up on different sites with my registration, which one do I need?
    First 2 from OEM parts...
    AUDI A3 (8P1) 2.0 TFSI FEBI BILSTEIN Thermostat, coolant
    And
    This one from EuroCarParts looks totally different...
    Audi | Euro Car Parts UK’s No.1 Car Parts Retailer
  4. gen.heinz guderian
    1,346
    126
    The first 2 are the same numbers/parts. Just buy genuine,the ECP one will fail.
  5. Aidy06
    412
    19
    I will buy genuine but why are the OEM ones and the ECP one totally different? I don't understand it
  6. OVRA3
    OVRA3 Well-Known Member
    1,079
    80
    I got mine from eurocarparts worked a treat :)
  7. Lewis583
    956
    91
    There is two different thermostat types, hence the difference in price etc.
    Version 1: It is possible to just replace the thermostat valve.
    Version 2: The thermostat & housing are a sealed component and hence to replace the thermostat you also have to replace the housing too. It is not possible to open it up due to it being plastic welded together.
    For what it's worth mine (2006 A3 20T quattro BWA eng. code) had version 2.
    My advise is, to echo the above comments, go to the main dealer and just give them your VIN/REG number and they will sort it out for you.
  8. Minstadave
    Minstadave Member
    560
    19
    I've had mine replaced twice now and it still fluctuates between 70 and 90 when its below 4 degrees. I've changed the coolant sensor twice too.
  9. Aidy06
    412
    19
    Mine takes ages to even move off the bottom, then stays at 70 whilst driving. If idle it goes to 90
  10. OVRA3
    1,079
    80
    Mines a 2005 and was also version 2
  11. Minstadave
    Minstadave Member
    560
    19
    Mine starts heating up after about 10 minutes, and won't hit 90 after a 30 mile commute if it's cold.
  12. Aidy06
    412
    19
    I can't seem to find the second version as an OEM part
  13. Aidy06
    412
    19
    Sounds like mine except mine takes longer than 10 mins to move off the bottom, is the car still safe to drive like this?
  14. Minstadave
    Minstadave Member
    560
    19
    Yup it's still safe. Mine does it every winter, it's almost at 100k now and not died.
  15. Aidy06
    412
    19
    Thanks for the input
  16. OVRA3
    1,079
    80
    Neeeeeeed moooorreeee innnpuuut sorry couldn't resist
  17. Aidy06
    412
    19
    Johnny 5 is that you???
  18. Lewis583
    956
    91
  19. Aidy06
    412
    19
    Got stat replaced yesterday, temperature now goes to 90 and stays there but can take upto 20 mins to get there. Any ideas?
  20. Minstadave
    Minstadave Member
    560
    19
    Normal in winter I think.
  21. Aidy06
    412
    19
    Thanks. Can anybody else with this engine confirm the length if time to heat up in the colder weather?
  22. audis3UK
    audis3UK New Member VCDS Map User
    10
    My coolant temperature runs at 87.00 C after a drive on the motorway, could this be a faulty thermostat?
