2.0T FSI rough start up and misfire for first 2 seconds ???
ahed Jul 10, 2010
  1. ahed
    ahed New Member
    21
    Hi
    Am having an issue with my Audi A3 2.0T FSI 2006, recently it started to have rough start up and misfire that lasts only a sec or two, then after no issues and runs like a dream!
    I got no fault codes on ecu, also vehicle had full service with new spark plugs and coils by Audi but still doing the same thing.
    Any one knows a reason for that? [​IMG]
    Many thanks in advance [​IMG]
  2. ahed
    ahed New Member
    21
    Any one with same issue pls?
  3. palexr
    palexr Member
    64
    I read Clarkson's review of the A5 2.0 TFSI and he mentioned the Audi TFSI engines sounding like diesels. He also really, really didn't like the car, in particular the start-stop tech.
    So maybe it is normal? Don't know yet as I haven't got my 1.8 yet. I can't remember the test drive car sounding rough, or having any problems with start-stop for that matter.
  4. dave_ph
    dave_ph Member VCDS Map User
    78
    10
    my s3 sounds like it struggles a bit quite reguarly for the first couple seconds when i start it up from cold. its only been doing it for the last couple months
  5. _G_
    _G_ Active Member
    876
    right same problem here...
    replaced the following: starter motor, battery, n80 valve, coil packs and spark plugs... and it is a bit better but still doing this some days...
  6. Minstadave
    Minstadave Member
    560
    19
    I think they all do this, mine does. I just ignore it.
  7. _G_
    _G_ Active Member
    876
    just weird as i never had this prob before from new and at 68k miles its started all of a sudden... oh well... no fault code no idea.
  8. Reevesy
    Reevesy Member
    39
    When was your cam follower last checked???
  9. VWAddict
    VWAddict Member VCDS Map User
    656
    9
    Intake and valve carbon deposits.
    Gets worse. -then it all has to be cleaned. -forget misting chemicals in, or RedEx or SeaFoam, or B+G... you ave to take off the intake manifold, soak the deposits in solvent and suck out the nasty soup. -Repeat. -Also the airflow separator plates get carboned up... lots of nasty pics floating about on the web.
    Mine started doing it at about 63,000 miles. Got worse, started running slightly rough, then started throwing codes, then under accelleration it would buck like a mule.
    $1400 worth of cleaning and injector replacement later, it was as smooth as warm butter again.
