2.0T cam follower replacement and look how bad this is!!
Lewbo Oct 27, 2011
  1. Lewbo
    Lewbo Well-Known Member
    1,266
    104
    Hi
    I have a 2.0T and had it for a year now great engine, but was looking at common faults the other day as my DV went few weeks ago and I changed my PCV valve too and read that the cam follower was very common problem and symptoms are fuel cuts, well sometime when my dsg gearbox changes gear it felt like a slight jerk like no fuel was there so anyways thought I would change the cam follower.
    Picked it up today from Audi and fitted it tonight only to find it like this: I have compared it with the new one
    So fitted the new one and it felt so much smoother when I changed into 3rd gear ect this was the worst gear before.
    What I wanted to know is would this of caused any damage to my engine at all I have looked at the cams through the hole and seemed fine to me, No damage it anything. Would this of made my car slower also with the old follower
  2. Lewis583
    956
    91
    Bloody hell, that's well knack'd mate. No scoring or grooves in the cam at all? If not then it seems you are very lucky.
    It would have had a slight affect on fuel pump plunger lift/pressure, but not enough to impact performance i would have thought.
  3. Lewbo
    1,266
    104
    I know I was gutted when I saw it, there where very tiny light marks on the cam nothing deep or anything like that, don't know how long it's been like that though, was very lucky that I just randomly decided to change it.
    Thought it was strange when I went to bleed the valve of the HPFP and there was nothing there would this mean anything :s?
  4. Lewis583
    956
    91
    Did you have the igntion on or drivers door open when you tried to bleed it?
    How much did the plunger cost you? I intend to strip mine at some point to check the condition.
  5. Lewbo
    1,266
    104
    No it disconnected the battery and door was closed, the cam
    Follower was £24 all in with vat well wort buying and changing even before you look at yours piece of mind to be honest mate
  6. rosco11
    rosco11 Member
    Can't believe the state of that! How many miles has it covered?
  7. Lewbo
    1,266
    104
    I know mate and has covered 33k so don't reckon it's ever been changed.
  8. warren_S5
    warren_S5 Moderator Staff Member Moderator VCDS Map User
    7,210
    2,486
    That's unbelievable considering your mileage.
    1) do you rev it hard from cold
    2) are you on fixed or variable long life serving
    3) do you drive the car hard
    I didn't manage anywhere close to that with HPFP & S2+ and similar mileage
  9. Silky-S3
    Silky-S3 Is loving his new 8V S3!
    1,407
    342
    33k!!!! Thats crazy! I changed mine a few days ago and it did not even have mark on it.
  10. drsilviuro
    drsilviuro Member
    121
    I'm 99% sure that you have to change intake camshaft and HPFP. I've had the same problem and put a new cam follower. After 30km (~20miles) the black protective coating had scratches on it! Need new cam follower or new HPFP? - VW GTI Forum / VW Rabbit Forum / VW R32 Forum / VW Golf Forum - Golfmkv.com replaced camshaft with S3 ones and new HPFP!
  11. Cheese
    Cheese Member
    182
    AmD recommend checking it every 5,000 miles if you have a HPFP. I think APR released a TB about it as well. You were lucky it wasn't worse - could have needed a new engine - I saw the aftermath of a similar problem on an S3 when I was in getting my car remapped. :slapped:
  12. marpou
    marpou Member
    34
    Hope all the metal missing is in the bottom magnetic plug ...
