2.0L TDI A3 TDI 140 oil consumption.
A1DEYB Apr 18, 2011
  1. A1DEYB
    A1DEYB Well-Known Member
    1,682
    43
    It's using a litre of oil every 5000 to 6000 miles, is this normal? I know modern diesels are supposed to drink a little but but a litre every 5K to 6K?!
    Cars a 56 plate S line sportback 2.0L TDI 140 (not mapped), done 35K and it's not been thrashed to death in theis period either.
    Comments/opinions welcome chaps.
  2. N8
    17,163
    718
    They drink like an.....
  3. A1DEYB
    1,682
    43
    So its normal then?
  4. N8
    17,163
    718
    Yeh :laugh:
  5. Gti Jazz Blue
    Gti Jazz Blue Active Member VCDS Map User
    1,655
    Mine must be odd then because it doesn't use a drop between services (yearly and I do about 9K a year).
    Paul
  6. Smoothie
    Smoothie Active Member
    1,431
    Thats between Audi limits yea, so it seems normal! Mine doesn't seem to use any TBH
  7. crunchie
    crunchie Active Member
    880
    77
    Mine was the same, 1 litre every 6/7k.
  8. A1DEYB
    1,682
    43
    Thanks for all the replies, as long as it's normal then that's fine.
    :thumbsup:
  9. a9503128
    a9503128 Guest
    All engines will use oil, the PD140 will thus the oil bag velco'd to the side wall in the boot.
    However you should NOT use more than 1ltr between scheduled services, tips are let your engine cool down after a run so your using the oil pump and oil to cool the engine. Letting an engine stand and cool will prevent high levels of unburnt hydrocarbons and moisture and condensation which will in turn dilute the oil and destroy the lubricating properties of the oil.
    Alex
