2.0 TFSI PRESSURE RELEASE VALVE PART No 06F129101N
REDNERRAW72 May 11, 2013
  1. REDNERRAW72
    REDNERRAW72 New Member
    Hi
    Just wanted to know if anybody else has had to change theirs. Apparently its a common fault the diaphram splits and causes a loss in boost! Cost £30.00 for the new part which has been improved and £15.00 for the gasket from the stealership.20 minutes job to change.
  2. wuta3
    wuta3 Well-Known Member
    1,124
    347
    Googles the PN ...
    Yea that's the PCV aint it? Mine went, caused rough idle etc. Not sure it causes boost loss tho .... My DV went tho and that caused boost issues.... not the same part tho .. are u sure that's the right part number? You might mean the DV which has a later revision (rev D) ... that splits and causes boost issues.
    The rev D diverter valve is 06H145710D
    Confused.
  3. REDNERRAW72
    Hi thanks for that!!Audi wakefield told me it was the part i have changed to fix problem but scanned again and it happened after i changed the part so will be getting this part that you have told me now!Many thanks
  4. wuta3
    1,124
    347
    Dont go spending money on my advice! Get a specialist to locate the problem first.
