2.0 TFSI Misfire/slight hesitation advice needed
B-J-P May 31, 2011
  1. B-J-P
    B-J-P Member
    78
    Hi,
    Wondered if anyone could help. I seem to be getting a misfire and slight hesitation when I accelerate, more noticeable at high speeds and particularly when overtaking.
    I have had a coil pack replaced a few weeks ago after which it was running fine.
    Just been into my local garage and he plugged it in and took it for a spin and couldnt find any problems.
    Anyone here had any experiences of this, I have a Bluefin stage 1 installed so may have to go back to superchips to investigate.
  2. antmax7
    antmax7 Member
    295
    is your car a s3 or standard 2.0T????
    as i know s3's seem to have a well documented problem with missing!
  3. jungleman
    jungleman Well-Known Member
    2,035
    42
    could be 1 of 3 things, coilpacks, plugs or maff... chances are that once one coilpack goes it strains the others so the others could follow soon after, so its always worth buying them in complete sets, also how old are your plugs? and another good test is to whip the plug that connects the maf out as sometimes they can be on there last legs and pack up causing problems
    also as already asked, what car is it and has t been mapped?
  4. Boydie
    Boydie S3 8V DSG VCDS Map User
    3,450
    588
    Did you only change one coil pack??
    If so, change the rest if one goes then there is extra stress on the others.
    Also check your spark plugs, when were they last changed?
    Have you vagcom? Any faults? I had a flapper failure and had to change the motor :(
  5. akash_sky1
    akash_sky1 Active Member
    1,181
    Check the DV as well, sometimes they can let go gradually and the let boost waver, causing hesitation, although not a misfire.
  6. B-J-P
    B-J-P Member
    78
    Thanks all for the advice, it is an A3 2.0T.
    I've only had the car a couple of months so not sure about the age of the plugs. Although it didnt come with all of the service receipts it is fully stamped within the service history booklet so has therefore undergone whatever was needed at each service stage by Audi.
    It has been remapped using a Bluefin, therefore I may try putting it back to standard and see if that makes any difference.
    Unfortunately dont have VAGCOM and I was under the impression that if you run the car without the MAF sensor connected then it throws up a fault that would need to be cleared?
    The problem is I dont want to start throwing money at parts which dont need replacing.
  7. dc240969
    dc240969 Member VCDS Map User
    925
    as was mentioned it could be coils, £35, plugs, cheap enough or it could be you down pipe. MAF, lm not sure on price. Hopefully its not your map.
  8. jungleman
    2,035
    42
    Well a rough break down of prices, coils £35 each, plugs £14 each and the big one, MAF £130ish so it's a bit of a drag but if you've have a misfire then for precautions I would change out all coils and plugs, also with a mapped car you ahould change your plugs much more frequently, I change mine every year as the extra fuelling will cause additional build up on them.
  9. Lewis583
    956
    91
    Audi are doing a recall currently on all petrol engines 1998 onwards for coil pack replacement, get it booked in with them to change the coil packs first. They may only change 3 because you already fitted a new/non genuine one.
  10. B-J-P
    B-J-P Member
    78
    Cheers, booked into Audi on Saturday as they will be changing coil packs under warranty ! They also confirmed they will be washing and hoovering the car whilst I wait so saves me a job.
    Apparently they will also do a visual healthcheck which I can watch via video link !
  11. S3RYE
    S3RYE Interior Next!!
    3,448
    70
    sounds alright!! good luck mate... Misfires are hell! :3sadwalk:
  12. dc240969
    925
    £35 for a set of coils l paid. £50 for a set of IK24 denso iridiums.
  13. jungleman
    2,035
    42
    you paid 35 for 4 coilpacks... they must have fallen off the back of a truck as no way will you get them anywhere for that price!
    the oem sparks im sure you can get cheaper then audi, 40 for a set of bosh plugs would be reasonable
  14. a8 tech back
    a8 tech back Member
    198
    Why do all think the mafs are faulty, they never are
    check fuel pressure and check misfire recognition, if its counting up on only one cylinder then its either
    compression, coil pack, plug partial blocked injector from carbon build up (if you scope the injector you will see the pattern alter showing partial spray)
    the crank sender devines the misfire as the rpm will alter thus the pre mapped crank revolution will ping the mil and hopefully pin point which cylinder
    just my findings and i work on these every day and have NEVER REPLACED A MAF ON A TFSI YET
    its normally poor remaps, vacuum leaks, plugs and injectors and in some cases camshaft and valve's sticking
    take your pick but check mvb's for misfire recognition before you do any thing
    note when a cylinder misfire is detected the ecu shuts the injector down and then re balances the fuel to smooth over the imbalance, this can catch you out
    if you have a vacuum leak then the lambda will pick this up so you can simply spray a solvent based aerosol like carb cleaner around the area and monitor the lambda values to determine if you have a leak
    misfire, use cylinder recognition measured values
    boost look at pressure for air and fuel and also valve timing
  15. Novocaine88
    Novocaine88 New Member
    Sorry to resurrect an old thread, but this sounds pretty similar to something that's just started happening to my A3 today. Had a successful MOT on Saturday along with a full service at Kwik Fit. Now today, as soon as I step on the accelerator pedal with more than say 60% pressure the car feels like it does when the traction control kicks in to stop the wheels spinning. It judders/jumps - can't hear anything that doesn't sound right though.
    At one point after testing that this was consistently happening, the orange engine light started flashing on and off after coming to a stand still. After driving away slowly, it went off again, with the same stuttering happening. No other warning lights have shown themselves other than the one time.
    Could this be a coincidence? I've never had any issues with the car until now, right after Kwik Fit have fiddled around with it...
    A quick Google led me here, so I think it's misfiring, but I don't know anything about engines to properly diagnose this problem. I think a friend has an OBD scanner, might this be able to tell me what's going on? Should I just take it back to Kwik Fit and get them to fix what potentially sounds like something they've not done right.
