The cam chain tensioner 'should' be checked during the rebuild Stu. I know mine was! It's definitely more likely that the cars that haven't 'yet' been repaired will experience the tensioner failure and as you said it can result in a new engine if the damage caused is extreme. It's related to the oil pressure in the head, when the tensioner 'relaxes' on turning the engine off there's a possibility of slip when the car is restarted and jump a notch or more. Resulting in bent pistons!!
It is definitely a good point and will be far more costly than the piston rings, pistons and conrods replacement.
Fitting a new engine would be cheaper. (I would prefer this option especially if it was a 2012 variant!)
I would hate this to happen to customers who have had the piston ring rebuild. Another problem that will need monitoring unfortunately then...
And this is exactly what happened to mine! Piston ring rebuild done in November 2013 at £0 cost to owner, Cam chain tensioner went in March 2015 (mileage 96k) - repair cost was £1800 (local Indy) and luckily pistons & head were not damaged.
This is a picture of my not so straight inlet valves: View attachment 60412
Ouch!
Just out of curiosity, do you know if the valves were cleaned when they did the rings? Just trying to gauge if that's just 18 months worth of deposits or more.
Please let us know how you get on mate. It'll be interesting to see how they deal with this case as you don't have full service history. I'm in a similar situation myself.
Sounds entirely likely. I don't recall anyone from VAG actually saying it was a bad batch of rings, though : That's just been the first guess of most of the weekend engineers here, myself included.First, this whole issue is horribly complex because you are dealing not with just one problem but several problems which interact. Second, he reckons that VAG have played down this issue as 'a bad batch of rings', when the truth is far more damning.
Joe90_guy, remember these are entirely different engines, just so happens that they are both VAG f*** ups leading to customer cost. Yes it seems to be a piston design "error" that causes the issues with the 2.0TFSI engines, but that is as far as the comparison goes, I am still a bit concerned about my wife buying a 1.2TSI engine car as while I find it convenient to continue buying VAG products (have VCDS!!), I am still to be convinced that VAG are getting their act together and stopping these cheap design errors blighting our cars.
I think the tensioners aren't normally replaced. I specifically asked for mine to be checked when the rebuild was done. They were fine and didn't need replacing.I hope as jwash42 said above, they use new updated tensioners when completing the rebuild for all cars.. .
My local Audi posted this on there website
Follow-up Statement – BBC Watchdog June 4 edition
...Initially this process wasn’t implemented as uniformly as it should have been across our network...
Yes. I asked Dr G on Pistonheads, who works for a home counties Audi 'indy' and is something of an audi guru. He said they'd had many cars with the oil consumption problem, but the timing chain issue was comparatively rare.sb, that's going to be another thing that will be worrying owners!
I'm hoping that this does not become another related problem!
I hope so mate!Yes. I asked Dr G on Pistonheads, who works for a home counties Audi 'indy' and is something of an audi guru. He said they'd had many cars with the oil consumption problem, but the timing chain issue was comparatively rare.
Ouch, that's Definitely something to be aware of unfortunately mate! How come you didn't fight Audi UK to cover at least some of the cost? If that happens to mine dare I say, I will be fighting for a new engine!
I hope as jwash42 said above, they use new updated tensioners when completing the rebuild for all cars.. Otherwise this thread will hit 6 figures...
I did email Audi to complain about the chain tensioner and they asked me which Audi centre my car was in and they would look into it.
However, at that stage my car was all ready in my local indy with it's front end and head removed.
The other thought here is that for Audi to have contributed towards the repair cost, my car would have to be repaired by them, and I bet the cost would have been twice the price of my indy, so probably a false economy.
Stu I can see why you left Audi! Iv spent a few hours today researching and looking at replacements but noMy timing chain went a year before I started having serious oil issues. It cost me £1,200 for the repair with Audi contributing towards the rest of the cost.
Merc comes close in looks and value! Yet... and Merc rear windows are weak
its gonna fail Ryan, but I think you know that already. just go through the oil test like they ask and take it back at 621 miles. Yours will obviously fail before then so its a foregone conclusion and you will be running them up before the 621 has elapsed telling them that the car needs oil. Just make sure they have a courtesy car in for you as mine took 3 weeks to fix or you will be without a motor whilst it is fixed.
without the full ASH, they may try to bill you 5K for the work and just negotiate down from there.I feel your pain. Upside is they may just fix it for free. There does not seem to be any hard and fast rules for FOC or paying from what I can tell.
Depends entirely on where you bought it from, when, and stuff like that. Assuming you recently bought it from a trader, then yes: Sale of Goods act applies. But you must give THEM the opportunity to resolve the problem first.Worse case scenario it fails the consumption test and they won't fix FOC do I have the right to take the car back to where I got it from on the grounds it was sold to me faulty or something along them lines?
Should def. be covered by sale of goods act. As its less than 6 months, they'd have to prove that the fault did NOT exist at the time of sale. But better to get it fixed by Audi if possible.I've had the car less than 2 month and bought it from MB motor group in Leeds.
Mike I have exactly same make/model/engine/colour.age as you (but its a quattro)and it was first registered in June 2011. Ive only had it for three weeks and had a long life service done for me immediately prior to purchase. After doing around 1k miles I see the oil level has dropped from full to three quarters and as such I have sent a mail to the Service Manager and his assistant at my local dealer asking for their input into my specific problem. Should I be calling Audi UK in the morning before calling my local dealership for an update?As above Ryan but as soon as the car goes in don't take any rubbish off the service advisors especially as it's the 1.8 TFSI!
Ensure Audi UK are formally aware and give them another call to see if they will open a case. It will certainly require a rebuild and you will get a good outcome..
@PDunne - Don't waste your time: Your car is using (by your figures) 1 litre every 4000 miles (min to max on the MMI is a litre). This is a consumption level most Audi owners would give their right arm for.
Monitor it, and if it gets to around a litre every thousand miles, take it in to your dealer.
Hope you didn't look at the Yell reviews for them? They look more than a little iffy. http://www.yell.com/biz/mb-motor-group-bradford-3424245/
As long as you bung a litre of oil in when prompted by the MMI gauge, you shouldn't have any problems. The 'high' and 'low' on the MMI gauge are like the high and low on a dipstick. When it's at 'low', there's still probably 4 litres in the sump. If the oil level message appears, stick a full litre in at the next convenient moment.Just didnt want it going bang on the motorway as its mostly this kind of driving I do.
