2.0 tfsi how to remove the air filter
stone100381 Aug 7, 2008
  1. stone100381
    stone100381 New Member
    how do i remove the air filter on my 2.0t ? is it under the main plastic cover on the engine ? cheers
  2. Highwayman
    Highwayman Member
    141
    Funnily enough, I did this very thing today!. Yes, it is under the plastic cover, but you need to follow a few simple bits of guidance. Iggu's recent thread about his intake has some very good advice, and I started a thread a couple of days ago that now contains some further hints and tips to remove the engine cover (basically getting the engine hot makes it a whole lot easier ;) ).
    Phil
  3. Highwayman
    Highwayman Member
    141
  4. stone100381
    cheers mate:salute:
  5. Rabbit222
    Rabbit222 Active Member
    708
    123
    43
    Got this info off the TEX. Its not an A3 but the engine cover is the same...
    1. Unclip the two metal clips.
    2. Unclip the MAF sensor and pull out of the way.
    3. Undo the air intake or undo the clip right behind the box area.
    X. Pull. Cuss. Repeat. After a few attempts, pull harder and wiggle cover out. But don't pull to hard or in the wrong place, you can crack the cover!
    These are the mount points (4 of them) on the engine. If there are any rubber pieces on the posts, pull them off and put them in the cover before re-assy.
    And here's the underside of the cover showing the mount points
    Fitting your new air filter
    1) Turn cover upside down (place on something soft, as to not scratch the top).
    2) Restore mounting bushings if you haven't done so yet.
    3) Depending on how you took off the cover, remove the intake hose and the clamp.
    4) Loosen 8 screws (circled in green). NO NEED TO REMOVE!
    5) Separate cover halves from the front. Slowly, as there are hinges at the rear (by heatshield).
    6) With pieces apart, change air filter.
    When putting pieces back together, start with the hinge, and hold the air filter--so it doesn't fall out. Make sure screws are still pulled out, or cover won't seal. Follow steps in reverse to restore cover back to service.
    All above thanks to Syntrix and Chuibacca from the TEX.
  6. jamiekip
    jamiekip Guest
    Good work that man!
    Mod's - maybe make this post a sticky???
  7. Rabbit222
    708
    123
    43
    Cheers mate.
  8. Highwayman
    Highwayman Member
    141
    When you refit the cover, make sure that you remember to reconnect the MAF, otherwise you will have the emission light on within 10 miles or so (so says the man who forgot when he did his today :whistle2:!)
    Phil
  9. Staz
    Staz is a retronaut Staff Member Moderator VCDS Map User
    6,206
    64
    You're better off posting a link to this thread (and Iggu's!) in the FAQs thread. We can't really have a sticky for every single How-To.
  10. JoeDN
    JoeDN New Member
