2.0 tfsi erratic idle...
yorksphil Oct 11, 2013
  1. yorksphil
    yorksphil New Member VCDS Map User
    25
    solved first problem, now enjoying the next one! not...
    looking for a bit more advice on a 2.0 tfsi...
    Been sat on motorway for a couple of hours, get off it and up to a set of lights and stop, and car is ticking over a bit rough, then revs up to 2000 rpm and drops back down to 800 ish...rpm, then a few seconds later does it again maybe 1600 rpm this time, and drops back again....
    left it for an hour and drove again, exactly the same thing happens on tickover, drives fine but occasionaly on throttle lift felt a bit harsh , as though fuel or spark had been cut for an instant...
    Any ideas what i should be looking at, ( Pcv, dv, or vacuum leak spring to mind) can't seem to find a definitive thread/ or similar on here....
    Thanks in advance folks....
    Phil.:ohmy:
  2. MrLapou
    MrLapou Well-Known Member
    1,233
    121
    vac leak.
    Take oil cap off to see if engine runs rougher.
  3. S3AMK20VT
    S3AMK20VT Member
    170
    sounds like coilpack, common faults
  4. s3_sid
    s3_sid Active Member
    368
    35
    sorry to jump in but when i remove my oil filler it runs very rough !! almost wants to stall is that a vac leak ?
  5. Ads
    Ads License to drive
    8,230
    608
    Pcv
  6. pinterovski
    pinterovski Member
    667
    88
    Check for any other leaks but i'm sure that PCV is broken!
  7. MrLapou
    1,233
    121
    no vac leak..
    cap removal simulates a vac leak, so engine's running fine
  8. prt57
    prt57 Active Member
    741
    221
    43
    Hi,
    I had this happen on our GTI 1.8T a couple of years ago and VW fixed it by cleaning out the throttle body, Been fine since.
  9. Artimus
    Artimus Shortback
    2,014
    483
    I had something similar on a previous car (although not a VAG) that had spent a couple of months sitting in traffic without a decent run out! fixed it by disconnecting the battery, then pulling the ecu fuse to reset the learned driving style and all was well again.
  10. yorksphil
    25
    Cheers for the replies folks,
    can't get oil cap off, definately being held by suction....
    going to look for problems tomorrow, weather permitting....:think:
    thanks again, Phil.
  11. Dan_Mol
    Dan_Mol Member
    46
    If suction behind oil cap, its PCV valve.
    06F 129 101 N - Valve - £32
    06F 103 483 E - Gasket - £16
    Could probably get away without gasket, easy DIY fix under airbox 4 Allen key bolts and its off.
  12. yorksphil
    25
    Thanks folks,
    new pcv and gasket fitted today.... tickover is now smooth,
    and turbo seems smoother and pulls harder...
    Or is it me imagining it?....
    thanks for the advice.... Phil :yahoo:
  13. Dan_Mol
    Dan_Mol Member
    46
    No mine ran a lot better with both parts replaced.
  14. kimhemm
    kimhemm Member
    66
    Not your imagination for sure. The old OEM PCV have been leaking for some time stealing your boost
