2.0 TFSI engine sounds like a diesel !!!!!
co55ie Aug 17, 2006
  1. co55ie
    co55ie Member
    305
    Has anyone else with a 2.0t powered car noticed that it sounds like a diesel on cold start up ?
    Its quite a rattley sounding engine even when warmed up well mine is anyway :blownose:
    Anyone else noticed this ?
  2. d3fy
    d3fy Active Member
    1,412
    yup - it does sound odd cold.
  3. mikep
    mikep Member
    591
    Yup the 1.8Ts sound like a bag of nails when they first start up too. The diesels often sound quieter, which is very worrying when you've just tuned one!!
  4. garypaul
    garypaul Member
    51
    Yep mine sounds like a diesel for a second or two when you first start it
  5. Covenant
    Covenant Member
    246
    Yeh, sounds like the noise of hydraulic tappets taking time to pump up?
  6. co55ie
    co55ie Member
    305
    glad its not just mine .
    After a good run open your bonnet and have a listen . The engine still has an almost diesel like clatter to it.
  7. Smudge973
    Smudge973 Member
    128
    Even worse on my non turbo FSI, it's due to the fact that the engine works in the same way as a diesel I understand. But to be honest not really noticed it on the Tfsi.
  8. co55ie
    co55ie Member
    305
    Why doesnt that surprise me :scared2:
    I really hate the noise a diesel engine makes and now I have a wannabe under my bonnet :keule:
  9. Smudge973
    Smudge973 Member
    128
    Classic - I want mine to be a V8.......
  10. madvw
    madvw Active Member
    2,489
    I guess it has to be because of the lower compression ratio that turbo'd cars run.
  11. Covenant
    Covenant Member
    246
    Gotta say I've not really noticed it either, will listen out tomorrow morning :)
  12. co55ie
    co55ie Member
    305
    enjoy
  13. johnmv55
    johnmv55 Member
    247
    I think it's because of the direct cylinder injection, it has two fuel circuits, one electrical from the rear and it also has a mechanical fuel pump mounted on the camshaft end, and they do inject direct into the cylinder which takes an awfull lot of pressure, they also do all kinds of daft stuff like retarding ignition timing on start up to "fire" the cat up quicker
  14. synthdood
    synthdood Member
    288
    Yeah, I have the diesel clatter in my non-turbo 2.0FSI and it is indeed rather loud on a cold start. I really hate that sound. Also the engine idles at about 1100 rpm the first minute or two and then settles at 850 or so. Is that normal? (My old vectra used to do that too)
  15. marriedblonde
    marriedblonde Active Member
    4,371
    I just turn the stereo up.
  16. cdb2
    cdb2 Member
    711
    Mine does the same, idles high and then drops when warmed up a bit, all cars I've had have done it, think it is becasue of the richer mixture to get it warmed up quicker?
  17. johnmv55
    johnmv55 Member
    247
    Yeah, it's to "fire" the cat up quicker to meet the emission tests, the cat only works when at a very high temp, hence the quick retarded ignition warm up period of 20 secs?
