2.0 TFSI Coil Packs on a 1.8T
Westy Dec 14, 2011
  1. Westy
    Westy Well-Known Member
    17,443
    1,105
    I've done a search and can only find a few mentions of the adapter plates to fit TFSI coils to a 1.8 engine.
    I know this was something that Bill and Tuffty have spoken about testing but I wondered if anyone else had any more info or test results.
    For those who haven't seen this before, have a little read here:
    http://www.seatcupra.net/forums/showthread.php?t=317788
    2.0T/FSI coil packs
    VWVortex.com - 2.0T Coilpacks and spark plug gap, trying random new stuff.
    *** 1.8T to 2.0T Coil Pack Coversion Kits *** - SEAT Cupra.net - SEAT Forum
    Basically you can run a bigger plug gap with the TFSI coils and therefore bigger spark = better performance.
  2. ScottD3
    ScottD3 I want your faulty electronics Supporter Team V6 quattro Audi A8 Audi S8 Team Akoya TDi saloon
    15,162
    1,123
  3. <tuffty/>
    21,572
    4,047
    Plan to see if I can try this once my engine is back together...
    I know Bill was planning on testing this on the Lupo but he hasn't had the time as yet...
  4. ScottD3
    15,162
    1,123
  5. Westy
    17,443
    1,105
    I'm assuming that you can run these coils on an AEB/AGU large port even thought they normally use bolt down coils?
  6. Jason.s
    Jason.s Active Member
    2,879
    348
    Yeah the adaptors bolt down anyway dont they. So they`ll bolt down as the old coils would and the push downs will slip in..?
  7. Dani_B19
    9,336
    391
    I need a set of new coils and want to know what these are like, if their **** i dont want to be chcuking £150 plus down the swanny.
  8. DJ_Troopa
    DJ_Troopa K1 Driver
    1,743
    15
    What's the advantage of having 2.0 TFSI coilpacks? I don't get it.
  9. Westy
    17,443
    1,105
    Did you read any of the links above? :moa:
  10. sportstractor
    sportstractor Chugger
    2,709
    I'm massively skeptical, but apparently a bigger spark gives you a better burn... Doesn't make sense to me, but some people are reporting gains
  11. <tuffty/>
    21,572
    4,047
    They won't work without spacers on TFSI coil packs...
    head is irrelevant as its down to the cam cover that holds the coil packs in...
    I have an AEB head and use the AMK cover... push ins fit... simples :)
  12. Westy
    17,443
    1,105
    Ahhh so my next question is, do you need push down rocker cover?
  13. badger5
    9,543
    2,022
    i will be "testing" these possibly over xmas break on lupo...
    we will see fact from fiction then
  14. Broken Byzan
    13,237
    465
    I am awaiting results to see the benefits. I know when i lost my old dumb coils and lost the ICM the car felt smoother. No reason to assume this will be any different, It should in fact be a much larger difference
  15. Andrew@A.L.D
    3,879
    617
    I have them already as people say you can run 1 mm gapped plugs and they more reliable
    I've not finished my extra modifications yet to the engine but will report back when its running
  16. <tuffty/>
    21,572
    4,047
    Dunno.. adaptors should negate the need for that but they are pretty cheap on eBay anyway...
  17. superkarl
    superkarl MAN OF STEEL
    9,553
    2,453
    dont all the rocker covers have holes for bolt downs. mine does.
  18. Westy
    17,443
    1,105
    Is there anyone in the UK that sells the adapters?
  19. <tuffty/>
    21,572
    4,047
    I know someone thats planning too :)
  20. Westy
    17,443
    1,105
    I gathered that :)
    I was after some to do some testing.
  21. Andrew@A.L.D
    3,879
    617
    You will be surprised to find out that there not that much from the US inc the coil packs
  22. Westy
    17,443
    1,105
    It's just the import tax and time it takes from the US that annoys me.
  23. Andrew@A.L.D
    3,879
    617
    Tax very little. Even with the tax the from the US the coil packs and adaptors are as much as just the coil packs alone in the UK
    Mine only took 2 weeks to come
  24. DJ_Troopa
    DJ_Troopa K1 Driver
    1,743
    15
    I'm stuck at work on a late shift and feeling very lazy, i think that says it all haha.
  25. Westy
    17,443
    1,105
    Loads of time to read now then ajay ;)
  26. <tuffty/>
    21,572
    4,047
    TFSI packs have more energy so allowing a larger gap to be run giving a fatter spark making combustion more efficient...
  27. s17atw
    s17atw Member
    43
    I am running these on mine with a N/A rocker cover [​IMG]
  28. Westy
    17,443
    1,105
    Where's the 4th coil pack :think:
    tom2001s3 likes this.
  29. s17atw
    s17atw Member
    43
    Its there mate, just hiding behind oil cap!
  30. Westy
    17,443
    1,105
    What's the rocker cover from?
  31. badger5
    9,543
    2,022
    yes.. watch this space.
    testing first...
  32. aragorn
    18,490
    855
    There are a couple of different versions of the adaptors, depending on wether your installing them in an AGU style rocker cover or the later push down cover.
    For AGU and other early cars running the "dumb" bolt down coils with a seperate ICM the conversion is a no brainer. We already now the later coils with the integrated drivers are more powerful, and the TFSI ones are more powerful again, and cheaper.
    The main advantage as i see it is that it allows you to run larger plug gaps. The TFSI coils will happily run a 1mm gap, whereas the older coils (even the latest R revision that audis fitting for free) need the plug gapped down to 0.7mm on higher power cars, and if you try to run a bigger gap theres a good chance you'll kill the coil. A bigger gap means more voltage is required to strike an arc, and that in turn means the spark itself is more powerful.
    One thing to note is that a few people have found issue with the 06H coils from the most recent engines. INA are recommending you stick with the 06E or 07K coils.
  33. Westy
    17,443
    1,105
    The old style AGU bolt down coils are also more expensive then the later push down ones. When I fit my AEB head next year I will keep my BAM rocker cover I think.
  34. ScottD3
    15,162
    1,123
    Is that a 100% 'yes' or a 'No but after testing I will'?
  35. <tuffty/>
    21,572
    4,047
    Ok... now I am confused... if you have a BAM cover why did you want to change it to fit the TFSI packs??? the adapters are designed to fit these covers..
    Bolt down coil pack cover..
    Push in coil pack cover...
    As you can see the push in type has the screw fixings already for the adapters...
    sakib likes this.
  36. Westy
    17,443
    1,105
    Tuffty, I currently have a BAM engine but I have an AEB large port head ready to go on in the new year. Before I even started looking at the possibility of using TFSI coil packs I was just going to swap the lot over and keep the AEB rocker cover with bolt downs. To be honest with you, I didn't realise that the heads and rocker covers were inter changable.
    So when I fit the large port AEB head next year I'll use my BAM cover instead of the AEB one. Hopefully that's a bit clearer now :think:
  37. <tuffty/>
    21,572
    4,047
    You have read my build thread right??? LOL ;P
    Yes, thats clear as mud :thumbsup:
  38. Westy
    17,443
    1,105
    Bits of it and a while ago. What part are you referring to? Something to do with mixing the heads and covers :)
  39. <tuffty/>
    21,572
    4,047
    Don't worry mate... I have swapped the head twice on my car with AEB large ports and used the original cam cover every time... probably loads of pics as usual...
    In summary, use your BAM cover and all will be good :)
  40. Westy
    17,443
    1,105
    Thanks, you've got me reading your thread from the beginning now anyway :blush:
