2.0 TFSi AMD remap
Stringster Feb 5, 2012
  1. Stringster
    Stringster Missed gear
    390
    Had my 2.0 TFSi A4 Avant special edition 2 remapped at AMD Essex yesterday:
    Before - Power: 219.5 Hp Torque: 246.9 Ib/ft
    After - Power: 262.6 Hp Torque: 292.3 Ib/ft
    Nice progressive map with similar curve to to the original - very happy on the drive home!
    Apparently, will take a few tanks of fuel to fully adjust to the new map and should be up to 270 Hp.
    When hard on the throttle there is a blip around 5500 revs which feels like bouncing off the limiter but this should smooth out.
    Overall, very happy. Just want the snow to clear so I can test it properly!
  2. razza1
    razza1 Well-Known Member
    3,042
    803
    Is this a quattro? Also it sounds like a stage 2 map with those figures, have you got a better exhaust and new high pressure fuel pump?
    Gates likes this.
  3. Stringster
    390
    FWD which is why I wanted a more linear map.
    No mods and a stage 1 map only. 220bhp as standard on the SE, but I think it maps the same as any 2.0 TFSi.
  4. razza1
    3,042
    803
    Surprised by those figures then, also at that output you may find you're not getting enough fuel and need a high pressure pump, might be why you're getting that blip near your top end of rev range.
    You must get a fair bit of wheel spin as well with that, I had a fwd drive version before this one and it span quite often in standard? One reason why I waited until I got quattro before mapping.
  5. hades-
    hades- Yorkshire & Humber Rep. Regional Rep VCDS Map User
    9,480
    646
    sounds alot for stage 1 should be around 245/250 hp ish
    what RR was it on
    but 270 does sound stage 2 ish
  6. solaris
    solaris Member
    415
    17
    those are some impressive figures, post up the dyno chart...good job AMD
  7. Stringster
    390
    (Resurrecting my own post)
    Been investigating the "blip" at WOT and have now also concluded it is fuel cut. Been back to AMD for diagnostic check, which found nothing. Tried to demonstrate the problem but was hard to do as it only occurs at WOT 4th gear plus, by which time speed is a bit excessive for the roads around there. They said to go back if it gets worse.
    Since then I've checked/changed cam follower (no wear) and fitted a RS4 pressure relief valve with no changes.
    One of the things I read that describes it well is the second point here:
    There are two fuel cuts being described here, one is ecu generated- higher gear wot for a few seconds and then BAM car cuts out all power and goes into "limp" mode and you cannot boost positive. That is your general fuel cut described by most people before they upgrade to an aftermarket hpfp.
    Second one is the hitting a fueling wall feeling, where Bassically your ecu doesn't ^see enough of a problem with your AFR to cut you into limp mode, but at the same time your not providing enough fuel at wot to spool the turbo to full boost pressure. Though at 3/4 throttle the fuel is enough for the lower amount of CFM.
    I love the map and it goes really well at low gears and 3/4 throttle - just annoying when WOT.
    So have now committed to upgrading the HPFP. Looks like the Autotech kit is the best option? Any other mods necessary?
  8. sewell10
    sewell10 Member
    236
    what is the cost of a high pressure fuel pump for a 2.0 TFSi quattro
  9. solaris
    solaris Member
    415
    17
    Think it definitely makes sense to upgrade the HPFP, may be worth investing in a better exhaust and high flow cat or de-cat. Also check you have the latest coil packs fitted as there was a recall by Audi.
    (Oh and if you fancy a FMIC pm me :))
  10. northernlight
    northernlight Member
    58
    I had mine done last week at AMD Essex as well. Started out as standard TFSI Quattro SE with Milltek cat back producing 216bhp according to chart. Had their own stage 1 remap done along with upgrading the diverter valve and adding a pipercross air filter. Now producing 258bhp and 290 ft torque according to figures.
    Feels like a huge difference on the road, always liked the imnitial torque kick, but then the boost seemed to tail off pretty quickly unlike my old Scoob STi. Now it kicks a lot harder and longer. Also on my way back home round the M25 the traffic precluded any fun so i though i'd test the mpg, got nearly 40 averaging just under 70 according to the obc. Not bad!
