2.0 TDI Misfire on start up.
P Crr Sep 9, 2010
  1. P Crr
    P Crr Member
    54
    I have 2005 2.0 TDI which when started after being stood overnight seems to misfire when 1st started. Car will run rough for a few seconds than clear and then run fine. After the initial start car will then start fine until left for a long time. The other day I left car for 2 days and problem was worse. I have had car plugged into diagnostic machine and no faults are showing. Any ideas??
  2. Wrath
    Wrath Well-Known Member
    1,196
    41
    I'm sure someone will step in here and say I'm talking cr*p but have you driven it until it's warm and then accelerated hard for a bit to make that any soot buildup is burned and kicked out of the exhaust?
  3. P Crr
    P Crr Member
    54
    Car is not driven that gentle anyway.
  4. AudiMafia
    AudiMafia Member
    403
    13
    car runs rough on cold start after few mins, but then it could be fuel pump!?!
  5. P Crr
    P Crr Member
    54
    No problems with running other than for a few seconds after cold start. No faults stored.
  6. albi
    albi New Member
    HI, I have exactly the same problem on a 2008 passat and was wondering if you had resolved the problem
  7. Wrath
    1,196
    41
    Possible EGR clogged up.
  8. outsideline
    outsideline Active Member
    295
    45
    look into injector leak off pipes. sounds like your getting air in there over time, is it taking long to crank then start???
    if you have any air getting into the fuel system it will leak off back to the tank.
  9. tubby
    tubby Member
    51
    is it using any coolant and do you get any white smoke from cold could be the start of head gasket leaking!burning of water building up in one of the cylinders...
  10. sidibear
    sidibear Looking for Zombies !! Staff Member Moderator Audi A4
    2,320
    767
    Is it making a clattering noise when it first cranks and fires?
