2.0 tdi lack of power
anilkumar Nov 16, 2010
  1. anilkumar
    anilkumar Member
    66
    my mates A has a problem has had vagcom scan and came up with MAF code and MAF changed codes cleared car still down on power scaned again comes up with
    16683 Boost Pressure Regulation: Control Range Not Reached
    what dose this mean is turbo faulty or is it a boost leak or n75 valve
    EGR has recenly been changed
  2. NHN
    29,295
    1,701
    Check your pipes from/to turbo all way to the inlet manifold, reckon could be a loose 1 if someones been messing with piping for egr, also check any connectors are pushed home ok.
  3. anilkumar
    anilkumar Member
    66
    everything seems to be conected up right can not hear a boost leak when car is running how else can a boost leak test be done
  4. anilkumar
    anilkumar Member
    66
    the problem was fixed. turbo was knakered and causeng car to go in to limp mode so got a recon turbo fitted and a new N75 valve
  5. NHN
    29,295
    1,701
    Which engine code was that on & if it was a bkd then it doenst have an n75 as such, it has a solenoid valve block that actually houses various valves, chances of that going are slim tbh if turbo goes.
  6. anilkumar
    anilkumar Member
    66
    its blb engine code it was the solenoid valve that was changed i think
