[2.0 TDI] How to know if your cylinder head will Crack (if it hasnt yet)?
amgad Jul 27, 2009
  1. chris11122
    chris11122 Member
    51
    10
    Thanks for that - will get looking for a new starter!
  2. Baza1819
    Baza1819 Member
    254
    What sort of money ya talking if head gasket gone ??
  3. tdi-man
    tdi-man Well-Known Member
    1,783
    64
    my heads cracked where the glow plugs come out and mines got the C part number. ;(
  4. tdi-man
    1,783
    64
    so what happens if the crack is between the glow plug holes in the head ?
  5. Boon
    Boon Active Member
    441
    59
    New head needed I'd say, you'll lose compression/burn oil
    Update on mine regarding hot start - had it remapped with hot start fix and all has been good since (same starter & battery that was advised to be replaced - they don't)
  6. tdi-man
    1,783
    64
    cool who mapped it ?
  7. tdi-man
    1,783
    64
  8. Boon
    Boon Active Member
    441
    59
    Rob at W8 Performance :thumbsup: (Shark map)
    BKD 140 mapped to approx 180bhp 400nm torque, EGR map out & hot start fix (fuelling adjusted on start-up when warm/hot afaik)
  9. Murraymint
    Murraymint New Member
    Do the 170 tdi's suffer from cracking heads
  10. bigal23
    bigal23 Member
    208
    does this happen after the cars been mapped or if its not happened after 97,000miles am safe?
  11. tdi-man
    1,783
    64
    a head can crack at any time it wants to
  12. s3reptdi
    s3reptdi Member
    179
    Mine is 03G 103 308 P? 55 plate done 101607, not had it long though
  13. mike foster
    3,967
    I think the 'P' will be a 'B'. You may have misread it ! Mine is an 05 plate but 06 MY like yours and mine is a 'B'
  14. s3reptdi
    s3reptdi Member
    179
    Your right, had to scrape some dirt away
  15. s3reptdi
    s3reptdi Member
    179
    Right my brothers head has cracked between all the valves, where have people got a new head from and how much? Any problems since?
  16. DA55TER
    DA55TER New Member
    13
    After reading this I've gone out in the rain to check mine...
    Mine is a 55 plate... but has a C head.... does this possibly mean the head has been replaced at some point?
  17. mike foster
    3,967
    Not necessarily but you should be ok anyway !
  18. lesteague
    lesteague New Member
    Brought a 53 plate 2.0 TDI and the part appears to have been replaced:03G 103 308 C although I have the warm start issue which is becoming annoying.
  19. SmithyAG
    SmithyAG Active Member
    414
    61
    Just got round to checking mine. Appears to end in an A and has done 120k with no problems.
    Has anybody any experience of them suddenly going at higher mileages? Or at 11years and 120k miles is it at the point where it would have cracked if it was going to?
  20. Mindak
    Mindak Active Member
    799
    130
    43
    Think mine might have finally started to go, using coolant with no signs of leaking and not mixing with oil! :(
  21. SAiLO
    SAiLO Well-Known Member VCDS Map User
    1,078
    62
    Could be the EGR Cooler leaking. Have you checked that?
  22. Dannymoto
    Dannymoto Active Member TeamMisano Audi A3 Black Edition
    544
    85
    My car doesn't like to start well in the morning, attempts to start then stalls...
    The car also isn't the smoothest of starts when its hot.
    I'm keeping an eye on the coolant, did notice some smoke this morning though.
  23. Mindak
    799
    130
    43
    My egr has been deleted so the cooler is blanked, there's no wet patches I can see so don't think it's leaking I think it's being combusted!
  24. Audid
    Audid New Member
    24
    Hello all. I hope this thread is open.
    I've been told that my 04 Audi A3 head gasket issues, the garage suggested a cylinder change. My question is, does it have to be a specific code as mentioned in post?
    Please let me know.
  25. John Quirke
    John Quirke New Member
    I have a 2005 Volkswagen Golf mk5 which when I bought it in 2008 had to get the engine replaced as it had the cracked cylinder. I was told at the time that a 2007 bkd engine was put in. The engine was fine up until 6 months ago when it started loosing coolant again and very smokey I just checked the number on the top of the engine and it is 03G 103 469N. Do any of ye know is this the trouble head number or could it be something more minor. Thanks for help
  26. Rideen
    Rideen Active Member Audi A3 Team Brilliant Black TDi saloon Manual
    766
    183
    43
    The part you listed is cylinder head cover mate. Look for the cylinder head number and post it. :)
