[2.0 TDI] How to know if your cylinder head will Crack (if it hasnt yet)?
amgad Jul 27, 2009
  1. amgad
    amgad Member
    51
    Basically, there are 3 references for the cylinder heads on your 2.0 Tdi BKD engine.
    Open the hood, remove the engin cover, and to the rightof the cylinder head, under the metalic fuel lines, you will see a references written upside down, with a letter at the end. Over in another forum, a survey was made with the following results.
    03G 103 308 A years 2003 to 2005.55 allmost all cracked
    03G 103 308 B
    years 2005.5 to 2006.6 only a few cracked
    03G 103 308 C years 2006.5 to 2007.5 none cracked cracked
    This means that for those of you who have had theirs replaced, or even with a new car, check out the letter on your reference for peace of mind.
    Hope this helps
  2. Batt284
    Batt284 Member
    98
    Cheers mate, that is very helpfull and is consistant with the problems I have seen others post on this forum.
    Annoyingly, they do tend to take some time to crack which often extends beyond the warranty period!
  3. amgad
    amgad Member
    51
    Sorry small mistake there, its to the RIGHT side of the cylinder head that you can find the reference written.
  4. tdisportuk
    tdisportuk Member
    460
    sticky?
  5. amgad
    amgad Member
    51
    would be worth it, best piece of info i have found about my care, sure sleep well now.
  6. Mikey
    Mikey Member
    885
    so are you saying that 56 plates never cracked? if so, your wrong coz mine did!!!
  7. amgad
    amgad Member
    51
    Your car has 56 plates? wow, where do you fit them.? Just joking,
    How about a year of production as a measure of time.
    jphc likes this.
  8. devonmikeyboy
    devonmikeyboy As far from JBS as possible !
    1,245
    As already stated, this should be made a sticky as very useful info for us diesel people.
  9. Hitharder
    Hitharder Member
    35
    for the enginely immature people what does this mean?
  10. devonmikeyboy
    1,245
    Every engine has a code. The engine code for the PD140 engine is BKD. The PD140 ( BKD ) engine soon got a bad reputation for the head cracking and or head gasket seal leaking. The earlier models where worst as the list above shows. The list is only a ruff guide though from people responces as i have known of 2007 BKD engines having head gasket issues. Hope this helps.
  11. Hitharder
    Hitharder Member
    35
    is there anyway of stopping it or is it inevitable? or should i get them changed how much etc? just bought a:
    55 plate sline 2.0 tdi DSG sportback
  12. amgad
    amgad Member
    51
    This info is not about the head gasket, its about the cylinder head itself.
    There is nothing you can do to prevent the head cylinder from cracking if it is going to crack, check your reference and you might be lucky. in spain, the head replacement is around 2500€, in UK at your hourly labour cost, probably more expensive.
  13. kaz219
    kaz219 Active Member
    1,808
    Just out of curiousity, what is it that actually causes them to crack?
    Poor manufacturing? Poor materials used?
  14. amgad
    amgad Member
    51
    Wall thickness or rather, "thiness". Audi had to redesign the structure of the head and reinforce a few areas. Sound like the origin of the resto of the problems Audi has COST CUTBACK.
    So eager to make a cheap producing car and sell it with a premium name and price tag. Other recurring problems in spain at least are,
    - DMF cheap and feable, when sachs has high torque ones, replacement is 1200 € and they fail over and over.
    - Electronic fan control goes south, fans dont stop, killing the batter 600€
    - Turbos, although this is not as bad as the cylinder head.
  15. Guys i have the question, if the cylinder head cracks what can happen? How does this effec manifests?
  16. just017
    just017 Member
    436
    Hmmm, now you got me shitting myself
    Mines a 55Reg BKD, i'll see what code i have after work
    What are sysmtoms of the cylinder head cracking?
  17. And in adition what can we do if we habe the cylinder head cracked. How can they be repaied?
    Mnay thanks.
  18. amgad
    amgad Member
    51
    Symptoms are: constant low coolant level, basically the coolant leaks into one of the cylinders and gets evaporated upon combustion. Eventually all coolant will disappear.
    Another symptoms is hard starting with lots of white smoke from exhaust during morning start ups and cold... this is due to coolant in cylinder.
    Final most noticable, is one cylinder locking up due to too much coolant.
    Only fix, is to replace cylinder head with a new one, C referenced.
    Hope this helps
  19. My car doesn't loose any coolant BUT in the morning it start pretty hard, i need to hold the key at the contact position for about 2sec, after that the car start normal. Can this be the cause?
    Another thing how ca i determine for certain that the cylinder head is cracked?
    Does anyone have an ideea of the price for a new one?
  20. Wai-Fan
    Wai-Fan Member
    530
    Hmmmmm, is there a way of checking whether it has been replaced or not?
  21. ianspibs
    ianspibs Member
    119
    My cylinder head is being replaced now under an extended Audi warranty.
    Sent car in for a routine service (70k) and asked them to check out excessive smoke under load / acceleration.
    No coolant loss but thinking back there has recently been a small amount of white smoke when cold starting, but not lots of white smoke.
    Audi now have a list of checks to be carried that will eliminate various other possibilities.
    Only then will they remove the cylinder head and send that away for testing.
    Car is 2005 - "05" plate.
  22. Darkrunner
    Darkrunner New Member
    Hi,i have one of this famous engines PD140 or BKD...engines that do things very niçe but have this Aquiles `Heel of the heads cracked in a unusual number.My is from 2007,March and have a 03 103 308 G R and in last November 2009 with just 85.000kms start to over heating.Head out at the plaçe i buy the car new and it was not cracked but the headgasket burn,I read very few here on cyberspace about the heads that dont crack but burn the gasket,and was this my case.Theres lots of material abiut cracked heads but for the ones of 2007 and newer that burn headgasket,very little.Can you help me if was just bad luck or there are more like me has you say in your post.By the way,the warranty pay the repair but i am a bit concern about next...if next 80 kms i get the some f*** problem..thanks for your time.
  23. Johnny Bravo
    Johnny Bravo 6+1 Gears Audi A3
    898
    70
    Hi!
    Can anyone point me in the picture below where exactly is the code stamped?
  24. Under those pipes. :)
  25. Johnny Bravo
    898
    70
    Right! Its a "B"! Hopefully the good one.
  26. bugwhizz
    bugwhizz Member
    144
    Hmmm, mines a B and it's using oil and water like it's going out of fashion!! but nobodys mentioned anything about oil usage??, just water usage??
  27. S1MON A3
    S1MON A3 Member
    44
    Just checked mine and its a C :? its a 2004 model and I have no service history record of a head swap.
  28. Batt284
    Batt284 Member
    98
    That is good new then :) It will have been changed for sure.
  29. S1MON A3
    S1MON A3 Member
    44
    Thats good news then :D
  30. nally
    nally MPG the new BPH
    2,104
    34
    how do you get the cover off ? lol mine dise spit black sh*t out every now and then is this normal?
  31. nally
    2,104
    34
    took the 10mm nut off but cant get it off??????? dont just wanna rag it off
  32. Jonay
    Jonay Member
    274
    you have to! I know its unnerving the first time, but just pull it gently on the three corners (excluding the top left!) and then slide it off the rubber bung on the top left (by pulling it towards you 20mm ish), you'll need to put that nut back on!
    to put it back on, just slide the topleft on as it came off and just align with the 3 black torx head screws that are sticking out with the rubber bungs on the underside of the cover.. and press down till they pop in.
    The plastic is stronger than you think!!
  33. mike foster
    3,967
    As Jonay says - yank it up vertically holding the front and right hand side ! It WILL pop off.
    Then pull towards the front to slide off the bit that you have taken the nut off !
    If necessary have a couple of pints first to pluck up courage :beerchug:
    Don't worry - you will NOT break it. :happy:
  34. nally
    2,104
    34
    cheers i broke the one on my 206 hdi gti (but it was french ) ill have a crack at it tomorrow hope i dont have the one that ends with the letter A
  35. mike foster
    3,967
    Mines a 2005 reg ( August ) 2.0l sport 140 TDi and it is a 'B' with no probs.
  36. nally
    2,104
    34
    mike whats on the clock
  37. Jonay
    Jonay Member
    274
    I'm interested too, I haven't checked the letter on mine, but I'm a September 2005 with 121k on the clock.... and I don't wanna jynx it!
  38. mike foster
    3,967
    Mine has 71k on the clock
  39. badgerbrock72
    badgerbrock72 New Member
    guys,
    im thinking of buying a march 2008 with this engine,
    being this new, will it have the 'C' (no worries) head..?
    cheers
    Garry
  40. badgerbrock72
    guys,
    cheers
    Garry
