DPF light came on last week; took it for a run on Saturday to clear it. It failed to clear and the 'glow plug' light has started to flash; then the 'emissions' light illuminated.
Other symptoms the cruise control has deactivated (I suspect this is normal and due to the engine faults), and the car is currently running in a torque limiting limp mode (150Nm).
I need to try and figure out why its not regenerating if anybody with more knowledge can review the scan below and possibly suggest a fix or something to look at it would be appreciated.
Also could it do any additional damage if I continue to drive it? Is there any way to force it to carry out a regeneration?
There are a couple of other faults but these are not issues to me currently.
I would light to thank JohnnyM100 on here who kindly came around, scanned, and logged it for me.
Monday,01,July,2013,18:51:00:00994
VCDS Version: Release 11.11.5
Data version: 20121222
Chassis Type: 1K0
Scan: 01 03 08 09 15 16 17 19 25 37 42 44 46 47 52 56 62 72
VIN: WAUZZZ8P1******* Mileage: 198650km/123435miles
01-Engine -- Status: Malfunction 0010
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
37-Navigation -- Status: Malfunction 0010
42-Door Elect, Driver -- Status: Malfunction 0010
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: Malfunction 0010
47-Sound System -- Status: OK 0000
52-Door Elect, Pass. -- Status: Malfunction 0010
56-Radio -- Status: Malfunction 0010
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
Address 01: Engine Labels: 03G-906-018-BMN.clb
Part No SW: 03G 906 018 DN HW: 03G 906 018 DN
Component: R4 2.0l PPD1.2 G 4350
Revision: --H42--- Serial number: AUX7Z0G5FNS0IM
Coding: 0000072
Shop #: WSC 00185 210 91035
VCID: 74E3EB1317B8CDB8354
2 Faults Found:
008194 - Particulate Trap Bank 1
P2002 - 006 - Efficiency Below Threshold - MIL ON
Freeze Frame:
Fault Status: 11100001
Fault Priority: 5
Fault Frequency: 11
Reset counter: 40
Mileage: 198402 km
Time Indication: 0
Date: 2013.06.30
Time: 09:14:38
Freeze Frame:
RPM: 1760 /min
Torque: 0.0 Nm
Speed: 0.0 km/h
(no units): 3.0
Pressure: 0.0 mbar
Lambda: 145.5 %
Time: 4492.8 s
Freeze Frame:
Fault Priority: 5
Fault Frequency: 6
Reset counter: 40
Mileage: 198565 km
Time Indication: 0
Date: 2013.06.30
Time: 20:28:52
Freeze Frame:
RPM: 2144 /min
Torque: 144.0 Nm
Speed: 0.0 km/h
(no units): 3.0
Lambda: 145.5 %
Pressure: 0.0 mbar
Time: 4492.8 s
Readiness: N/A
Address 03: ABS Brakes Labels: 1K0-907-379-MK60-F.lbl
Part No SW: 1K0 907 379 AC HW: 1K0 907 379 AC
Component: ESP FRONT MK60 0101
Revision: 00H11001
Coding: 0023170
Shop #: WSC 06314 000 00000
VCID: 73E1E80F12B6CA802CE
No fault code found.
Address 08: Auto HVAC Labels: 8P0-820-043.lbl
Part No SW: 8P0 820 043 AG HW: 8P0 820 043 AG
Component: KlimavollautomatH19 0420
Revision: 157516 Serial number: 8P0820043AG
VCID: 71EDE20768AAF890DE2
Address 09: Cent. Elect. Labels: 8P0-907-279-30-H.lbl
Part No SW: 8P0 907 279 K HW: 8P0 907 279 K
Component: Bordnetz-SG H54 2501
Revision: 00H54000 Serial number: 00000007300577
Coding: 01880F01B0141000471600001600000000085E175C010000000000000000
Shop #: WSC 06314 000 08192
VCID: 458566D70CA2043052A
Subsystem 1 - Part No: 8P2 955 119 E Labels: 1KX-955-119.CLB
Component: Wischer AU350 H01 0130
Coding: 00062736
Shop #: WSC 06314
Address 15: Airbags Labels: 8P0-959-655-94.lbl
Part No SW: 8P0 959 655 L HW: 8P0 959 655 L
Component: Airbag 9.41 H01 4210
Revision: 91H01421 Serial number: 003CP00029W/
Coding: 0071612
VCID: 4B9150EF2AC6F24084E
Address 16: Steering wheel Labels: 1K0-953-549-MY8.lbl
Part No SW: 1K0 953 549 AH HW: 1K0 953 549 AH
Component: J0527 036 0070
Coding: 0000042
VCID: 78FBDF230BD0A9D819C
Address 17: Instruments Labels: 8P0-920-xxx-17-MY8.clb
Part No SW: 8P0 920 981 K HW: 8P0 920 981 K
Component: KOMBIINSTR. VDO H20 0640
Revision: D0H20001 Serial number: 2245G001001991
Coding: 0004428
Shop #: WSC 00185 210 88124
VCID: 408B77C31380211861C
Address 19: CAN Gateway Labels: 1K0-907-530-V3.clb
Part No SW: 1K0 907 530 L HW: 1K0 907 951
Component: J533__Gateway H15 0180
Revision: H15 Serial number: 1400K076238264
Coding: E9807F065002022103
Shop #: WSC 00185 210 89734
VCID: 306B2703A320B19891C
Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb
Revision: D0H20001 Serial number: AUX7Z0G5FNS0IM
Shop #: WSC 00000 000 00000
Address 37: Navigation Labels: 8E0-035-192-RNSE.lbl
Part No SW: 8P0 035 193 G HW: 8P0 035 193 G
Component: RNS-E PU EU H05 0200
Revision: 0000011S Serial number: AUZBZ7KD200776
Coding: 0205755
Shop #: WSC 00079 211 08191
VCID: 34632B1357388DB8F54
3 Faults Found:
00858 - Connection; Radio ZF Output to Antenna Amplifier
007 - Short to Ground
Freeze Frame:
Fault Status: 01100111
Fault Priority: 5
Fault Frequency: 1
Reset counter: 187
Mileage: 186254 km
Time Indication: 0
Date: 2012.07.29
Time: 00:05:02
Freeze Frame:
Mileage: 186250 km
Count: 2907
Clock: 00:04
00466 - Control Module for Steering Column Electronics (J527)
008 - Implausible Signal
Freeze Frame:
Fault Status: 01101000
Fault Priority: 5
Fault Frequency: 1
Reset counter: 187
Mileage: 186254 km
Time Indication: 0
Date: 2012.07.29
Time: 00:04:49
01303 - Telephone Transceiver (R36)
004 - No Signal/Communication
Freeze Frame:
Fault Status: 01100100
Fault Priority: 5
Fault Frequency: 1
Reset counter: 187
Mileage: 186254 km
Time Indication: 0
Date: 2012.07.29
Time: 00:04:55
Address 42: Door Elect, Driver Labels: 8P0-959-801-MIN3.lbl
Part No SW: 8P0 959 801 K HW: 8P0 959 801 K
Component: Tuer-SG H03 0040
Coding: 0000688
VCID: 438178CF02963A007CE
1 Fault Found:
00915 - Window Regulator Switch; Rear Right; Driver (E55)
008 - Implausible Signal - Intermittent
Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb
Part No: 1K2 909 144 M
Component: EPS_ZFLS Kl.079 H08 1901
Shop #: WSC 02069 000 90108
VCID: 3667111B41449FA8CB0
Address 46: Central Conv. Labels: 8P0-959-433.lbl
Part No: 8P0 959 433 J
Component: KSG H10 0080
Coding: 1980202002186D0985054C9FC637
Part No: 1K0 951 605 C
Component: LIN BACKUP HORN H03 1301
Part No: 1K0 907 719 C
Component: Neigungssensor 005 0003
Part No: 8P0 951 177
Component: Innenraumueberw.H04 0020
1 Fault Found:
00956 - Key 2
005 - No or Incorrect Basic Setting / Adaptation - Intermittent
Address 47: Sound System Labels: 8Px-035-382.lbl
Part No SW: 8P4 035 382 D HW: 8P4 035 382 D
Component: AB2 SUBWOOFERBOXH06 0180
Revision: 00005 Serial number: 30674703039264
VCID: 356516175C4294B0C2A
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN3.lbl
Part No SW: 8P0 959 802 K HW: 8P0 959 802 K
Coding: 0000688
VCID: 44837BD307983D38454
1 Fault Found:
00936 - Electric Window Switch in Front Passenger Door (E107).
Address 56: Radio Labels: 8E0-035-192-RNSE.lbl
Coding: 0205755
3 Faults Found:
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 187
Mileage: 186254 km
Time Indication: 0
Date: 2012.07.29
Time: 00:05:02
Freeze Frame:
Mileage: 186250 km
Count: 2907
Clock: 00:04
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 187
Mileage: 186254 km
Time Indication: 0
Date: 2012.07.29
Time: 00:04:49
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 187
Mileage: 186254 km
Time Indication: 0
Date: 2012.07.29
Time: 00:04:55
Address 62: Door, Rear Left Labels: 8P4-959-801.lbl
Part No SW: 8P4 959 801 E HW: 8P4 959 801 E
Component: Tuer-SG H04 0040
Coding: 0000144
Shop #: WSC 06314 000 1012544
VCID: 418D72C7188A28106E2
Address 72: Door, Rear Right Labels: 8P4-959-802.lbl
Part No SW: 8P4 959 802 E HW: 8P4 959 802 E
Coding: 0000144
VCID: 428F7DCB1D8C3308778
End ---------------------------------------------------------------------
Chassis Type: 1K0
Coding: 0000072
2 Faults Found:
Freeze Frame:
Fault Priority: 5
Fault Frequency: 11
Reset counter: 40
Mileage: 198402 km
Time Indication: 0
Date: 2013.06.30
Time: 09:14:38
Freeze Frame:
RPM: 1760 /min
Torque: 0.0 Nm
Speed: 0.0 km/h
(no units): 3.0
Pressure: 0.0 mbar
Lambda: 145.5 %
Time: 4492.8 s
Freeze Frame:
Fault Priority: 5
Fault Frequency: 6
Reset counter: 40
Mileage: 198565 km
Time Indication: 0
Date: 2013.06.30
Time: 20:28:52
Freeze Frame:
RPM: 2144 /min
Torque: 144.0 Nm
Speed: 0.0 km/h
(no units): 3.0
Lambda: 145.5 %
Pressure: 0.0 mbar
Time: 4492.8 s
Readiness: N/A
Revision: 00H11001
Coding: 0023170
Coding: 00062736
Shop #: WSC 06314
Coding: 0071612
Coding: 0000042
Coding: 0004428
Coding: 0205755
3 Faults Found:
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 187
Mileage: 186254 km
Time Indication: 0
Date: 2012.07.29
Time: 00:05:02
Freeze Frame:
Mileage: 186250 km
Count: 2907
Clock: 00:04
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 187
Mileage: 186254 km
Time Indication: 0
Date: 2012.07.29
Time: 00:04:49
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 187
Mileage: 186254 km
Time Indication: 0
Date: 2012.07.29
Time: 00:04:55
Coding: 0000688
1 Fault Found:
1 Fault Found:
00956 - Key 2
Coding: 0000688
1 Fault Found:
Coding: 0205755
3 Faults Found:
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 187
Mileage: 186254 km
Time Indication: 0
Date: 2012.07.29
Time: 00:05:02
Freeze Frame:
Mileage: 186250 km
Count: 2907
Clock: 00:04
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 187
Mileage: 186254 km
Time Indication: 0
Date: 2012.07.29
Time: 00:04:49
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 187
Mileage: 186254 km
Time Indication: 0
Date: 2012.07.29
Time: 00:04:55
Coding: 0000144
Coding: 0000144
