2.0 tdi cold start problem
Discussion in 'A3/S3/Sportback (8P Chassis)' started by abpostelnicu, Jun 1, 2011.
  1. abpostelnicu
    Oct 22, 2006
    274
    Hello guys,
    For a while i've started having problem with the start of the start of the engine when cold. I've refubished the start engine and the problem is still there. I plan to test the HPFP pump located on the right part of the engine. What should i test for it using vcds. I know that it should do a minimum of 6 bars.
    Any adivise is well apreciated.
    Thank you!
  2. Advert Guest Advertisement
  3. a8 tech back
    a8 tech back Member
    Apr 2, 2011
    197
    you need .50 bar residual and at least 270 rpm cranking speed
    check there is no excess soot in the fuel from blow pass at the injectors, this will cause poor combustion and pressure drop
    connect a clear fuel pipe from the filter to the tandem pump and watch for air bubbles when cold cranking
    connect a ammeter to the pre supply pump cables and see what it draws when cranking
  4. abpostelnicu
    Oct 22, 2006
    274
    thank you, can i test the hpfp during engine running using the vcds?
