2.0 TDI BKD ENGINE- CUTTING OUT??? PLease Help
Eazyd May 24, 2013
  1. Eazyd
    Eazyd New Member
    17
    Hi All,
    My partner has a VW EOS 2.0 TDI 140 BHP (BKD ENGINE) 2006 before you say I know get an Audi like I did :) lol
    She was driving today to work when all a sudden the car just cut out while driving the ignition is still on, there are no signs of it looking like a electrical issue but when the accelerator is done even flat down there is nothing? I can only refer to it as a power cut. She was obviously worried but all of the sudden it accelerated again and seemed fine?
    She drove it back from work earlier and it was fine but the engine management light came on? obviously I checked it out as soon as I got back and it did the same to me? You can drive normally turbo pulls as it should etc but all of the sudden a power cut even when your foot is slammed down to the ground nothing??? Change gear and it comes alive again? but not like a jump start?
    I know it needs to be plugged in to a VAGCOM but unfortunately my brother has mine is away over the Bank Holidays (Typical).
    I don't really want to go and pay an Indie when I can do it myself but as it is baffling I just wanted to know if there are any suggestions?
    :uhm:
  2. SAiLO
    SAiLO Well-Known Member VCDS Map User
    1,075
    62
    Check VCDS users map thread maybe there is someone near you willing to help.
  3. AudiMafia
    AudiMafia Member
    403
    13
    Had the same issue to mine the car would suddenly cut off while i was driving, you need to reset your better remove both lead - and + and hold it together for 60secs and that will reset since I've done that no issues since
  4. Eazyd
    Eazyd New Member
    17
    Hold Together???
    The positive and negative wire???
    Are you sure?
  5. Geraldy212
    Geraldy212 Sportback owner
    565
    42
    Yes, if you first disconnect the cables away from the battery, and then touch them (the cables) together, you will discharge any residual current remaining in the electrical system. That should cause the system to reset itself when you next reconnect the cables to the battery. Good luck.
