2.0 tdi accelerate problem
mm707 May 26, 2012
  1. mm707
    mm707 Member
    267
    10
    Hi,
    The car runs fine when cruising along but when I accelerate there is a slight pause and stutter before it actualy accelerates. it also does it on cruise control when you lift the stalk. It's had a new egr about 5k ago as well as 4 injectors and loom on recall about a year ago.
    I've started by putting in a new fuel filter but it's made no difference.
    Any ideas where to look for a diy attempt at resolving this ?
    2.0 TDI 170 2007
  2. Wrath
    Wrath Well-Known Member
    1,196
    41
    Sounds like there maybe a hole in a hose possibly the one leading from the EGR.
  3. Mr.Sline
    Mr.Sline New Member
    Let me know how you get on pal, iv got the exact same problem, very annoying..
  4. jaygeezer871
    jaygeezer871 Member
    166
    Does the engine stutter when the car is stationary out of gear?
  5. mm707
    mm707 Member
    267
    10
    no - slightly uneven tickover now and then but other times its fine. Going to put some millers injector cleaner through this weekend and see if it makes any difference.
  6. jaygeezer871
    jaygeezer871 Member
    166
    Assuming its manual could it not be transmission ie clutch & dmf rather than engine as it only does while on the move?
    Im no expert but thinking it through logically having read all the past threads on forums like this?
  7. Wombatwilson
    Wombatwilson New Member
    12
    Does this happen around 1600-1800rpm?
  8. mm707
    mm707 Member
    267
    10
    I guess it probably does - I'll have a look next time I'm out but it is definately just as I'm accelerating
  9. podgemasterson
    podgemasterson New Member
    12
    I have the very same problem and yes thats when it happens, so annoying
