2.0 tdi a3 140. What head can I use? Nd list of parts.
aterro Nov 3, 2010
  1. aterro
    aterro S3 YO
    272
    Got a a3 tdi 2.0 sport 140
    Bkd engine I think.
    Needs new head. Suffix a I've got
    Wa other heads fit? Eg Ibiza ones? 1.9?
    Wen changing heads could you list all parts I need?? Cheers
  2. devonmikeyboy
    devonmikeyboy As far from JBS as possible !
    1,245
  3. aterro
    aterro S3 YO
    272
    What suffix head is that???
    Could you also list all the new parts needed??
  4. aterro
    aterro S3 YO
    272
    Bumpp!!!
  5. mike foster
    3,967
    Surely it can't be reasonable to expect anyone to list out the miriad of parts necessary to fit a new head ?
    There must be hundreds !
  6. devonmikeyboy
    1,245
    To swop the head over you need a head gasket, head bolts,cam bolts and injector bolts. The head i have advertised is a 03G 103 373 A . If you click on the following link for SCN where the classified section actually works you can see pictures etc.Standard PD140 BKD head. - SEAT Cupra.net - SEAT Forum
  7. aterro
    aterro S3 YO
    272
    Don't want another suffix a head as all of them crack according to research.
    Will any other heads fit? Eg the pd150? Or pd140?
  8. aterro
    aterro S3 YO
    272
  9. devonmikeyboy
    1,245
    The BKD engine is a PD140. The only other head to fit a BKD PD140 engine is the PD170 head but you need to remove the cams as they are different. Not all A suffix heads cracked and £150 for a pressure tested head compared to £800 + for a new one.
  10. aterro
    aterro S3 YO
    272
    What is the difference between suffix a b nd c heads??
  11. mike foster
    3,967
    Quite a few 'a' heads cracked
    Very few 'b' heads cracked
    No 'c' heads cracked (yet)
    If devonmikeyboy is selling a pressure tested head it doesn't matter what suffix it has, it'll be ok.
    And if it isn't I'm sure he'll sort it.
  12. devonmikeyboy
    1,245
    03G 103 373 C suffix is stamped on both the late PD140 heads and the PD170 heads as they are both designed and made the same way.
  13. vw754
    vw754 vorsprung Durch Technik
    2,336
    58
    Any ideas where exactly it is stamped ...pics ? any other ways to tell ?
  14. mike foster
    3,967
    As you look from the front of the car - right hand side of the engine underneath the fuel pipes.
    Obviously you have to remove the cover first !
  15. devonmikeyboy
    1,245
    The picture below shows what the 03G 103 373 stamp looks like on the head.
  16. aterro
    aterro S3 YO
    272
    so the pd140 heads are the same as pd170 par cams?
    what is the suffix a heads made out of incomparision for the suffix C heads?
  17. devonmikeyboy
    1,245
    Both PD140 and PD170 heads are stamped 03G 103 373C
