2.0 tdi 140 juddering problem again
Jord Mar 7, 2011
  1. Jord
    Jord Member
    280
    I know it's been brought up many times, but I can't seem to find the exact problem
    Basically the problem is when I'm cruising, mainly in 3rd or fourth gear just under where the turbo kicks in, it starts spluttering, it's like it what's to power the turbo up but still what's to cruise, once I get past that rev band it's ok then,
    I'm getting the vagcom on it at the weekend to check,
    Also got a coolant fault, which I think is the level sensor,
    Any help would much be appreciated,
  2. Jord
    Jord Member
    280
    Also aswell, it doesn't seem to do it all the time either, and does it with cold engine and hot, also when idling at traffic lights it sometimes shake the car about abit
  3. Lings
    Lings Active Member
    2,059
    31
    Mine has a slight pullsing vibration on tick over .I thought they all did this?
  4. Jord
    Jord Member
    280
    I'm not too bothered about the tick over, my old polo tdi used to do it, it's just the spluttering
  5. fizz
    fizz Member
    264
    Im getting the exact same so any advice would be appreciated. Had a new clutch and flywheel under warranty and its done it since then. Get it mainly in third too.
  6. Jord
    Jord Member
    280
    Just had vag com linked to it, juddering problem is a dodgy fuel sensor due to a shitty chip someone had on it before I bought it, and also needs a new coolant bottle
