2.0 PD170 engine failures *Warning?*
Beddie Feb 28, 2007
  1. Beddie
    Beddie Member
    240
    Hiya all...
    Just noticed a post over on briskoda about sudden and catastrophic failure to a few PD170 units, apparently due to the oil pump failing and disintergrating... [​IMG]
    Have a look at: http://www.briskoda.net/forums/new-octavia/2-0-tdi-170-engine-failure/74145/
    Does indeed seem like this engine is cursed with woes imo, poor economy for a diesel, issues with the DPF when remapped (a couple of DPF's have become blocked and caught fire due to this!) and now this..
    Hope no-one on here is affected although all cars will be covered by warranty i suppose [​IMG]
    HTH
  2. Caesium
    Caesium My BM is fixed! VCDS Map User
    4,879
    whats the DPF?
  3. Beddie
    Beddie Member
    240
    Diesel Particulate Filter mate.. :icon_thumright:
  4. Caesium
    4,879
    BTW amusing skoda forum name there
  5. rich1068
    rich1068 Member
    674
    I used to think it was started by a bloke called Brian.
    I don't pretend to understand diesels but isn't that the thing that's holding back the 170 remap from various tuners?
  6. Beddie
    Beddie Member
    240
    Spot on Rich, perhaps you understand diesels better than you think, you'll be buying one next...lol! :)
  7. rich1068
    rich1068 Member
    674
    Taxi...!
  8. Beddie
    Beddie Member
    240
  9. steve184
    steve184 Active Member
    1,138
    jeeez now you tell me - pickin it up on friday!!!!!
  10. h5djr
    9,173
    1,572
    Don't worry about it - it's probably already been identified are sorted. If anything like it does happen you'll get a new engine!
    I would guess that the tuners problems are related to the DPF. It's a new 'thing' and I think it's still only fitted to the 170 engine. The tuners are probably having to work out how to cope with making an engine produce more power and still have the exhaust cleaned by the DPF. It's the DPF that allows the 170 engine to have straight exhaust pipes.
  11. vagman
    vagman Member
    102
    I've done 5,500 since getting it in October and it hasn't put a foot wrong.
    Mpg wise, I get 40 (actual) and that is with driving it quite(erm..very) hard.
  12. rich1068
    rich1068 Member
    674
    *cough* coil packs *cough*
  13. vagman
    vagman Member
    102
    And??
    That problem was a few years ago and was quickly dealt with by VAG.
  14. rich1068
    rich1068 Member
    674
    [ot] 'Quickly' isn't the word that springs to mind when I think of how VAG dealt with the coil pack issue. [/ot]
  15. Vertigo1
    Vertigo1 Well-Known Member
    3,381
    542
    When faced with replacing entire engines under warranty I think they'll be fairly quick sorting this problem out.
  16. Caesium
    4,879
    They only dealt with this when you reported a fault to them, my GTI had a misfire which they then discovered was coil packs, I insisted that they change all of them, as they were only going to change one, so they did!
  17. h5djr
    9,173
    1,572
    Audi tended to replace the coil packs when either one failed or when it went in for servicing. Not quite the same situation as a broken engine.
    One of the coil packs on my A3 1.8T Sport packed up when I was away for the week-end. An ADT came out in his A6 Allroad and replaced all four in the hotel car park. When the car next went in for service, the service advisor checked on central system and could see that they had already been replaced otherwise they would have done it during the service.
