V6 PWR - 3.0 Quattro
I scan my A6 today and this error comes under enigne faults - p0597. There is no CEL and car drives fine. What could be the cause of it? Also can this be the cause of poor fuel consumption.
Can anyone shed some light how to resolve it as it's keep coming back after clearing it.
Quick google suggests its to do with the thermostat control
If that is stuck open then the car will throw the fuel in as it thinks its cold and thus could be the reason for your poor fuel consumption
Or one of the temp sensors is kaput
Does your coolant gauge reach and stay at 90??
The fact it's electrical and you can't clear it would point to a sensor rather than the thermostat
Yeah temperature sits at 90 when car is fully warm. I need to check sensor I guess
Reactions: Danny-boy
As I mentioned earlier, temperature sits on 90 and there is no CEL on dash. I am guessing it could be sensor on EGR that could be faulty. Any suggestions?
Here is the scan under engine module showing the fault
Code:
Friday,17,February,2017,15:15:29:25423
VCDS Version: Release 17.1.2 Running on Windows 10 x86
www.Ross-Tech.com
  Address 01: Engine  Labels: 059-907-401-V2.clb
Control Module Part Number: 4G0 907 401 F  HW: 4G0 907 401
  Component and/or Version: BSR v1 OY12SV X37 0004
  Software Coding: 0A254012052601020000
  Work Shop Code: WSC 01286 386 08256
  ASAM Dataset: EV_ECM30TDI0114G0907401F 001004 (AU57)
  ROD: EV_ECM30TDI0114G0907401F.rod
  VCID: 2643A6A259844271B9-8072
1 Fault Found:
7036 - Thermostat for Mapped Engine Cooling (F265)
  P0597 00 [047] - Open Circuit
  Confirmed - Tested Since Memory Clear
  Freeze Frame:
  Fault Status: 00000001
  Fault Priority: 2
  Fault Frequency: 1
  Mileage: 87126 km
  Date: 2017.02.17
  Time: 22:41:08
  Engine speed: 0.00 /min
  Normed load value: 0.0 %
  Vehicle speed: 0 km/h
  Coolant temperature: 81 °C
  Intake air temperature: 28 °C
  Ambient air pressure: 1020 mbar
  Voltage terminal 30: 11.920 V
  Unlearning counter according OBD: 40
  Accelerator pedal travel: 0.00 %
  Coolant temperature at radiator outlet: actual value: 19.7 °C
  Heat delivery temperature in cooling system: -273.1 °C
  Outside air temperature: 7.5 °C
  Fuel consumption: 0.00 l/h
  Fuel temperature: 50.9 °C
  Engine oil temperature: 77.2 °C
Readiness: 0000 0000
Got the part today, thanks to Mike from Wocester Seat for sorting it so quickly with discounted price. Car is booked for the fitting tomorrow. Fingers crossed it should clear the fault code and imporve fuel efficiency.
Afc2f1a57964634f2001391a2914438b
Fc640f18d40bb9654a134993ef3e31b3
Reactions: Rhyso
Got oil filter housing replaced and F265 is gone. Let's see how much miles can I get now out of full tank.
Very nice results did MSL do the tune?
No, I only went there to use dyno and quite frankly the way they initially did the run. I won't let them touch my car for any work.
After the run, they even didn't bothered to clear the faults. What if I didn't have the VCDS, imagine driving around with fault code on dash or have to go somewhere and pay extra to clear them
Yikes doesn't sound good, surely removing faults which enevitably come with dynoing is standard practice. Who did your tuning then?
While driving behind traffic I noticed today my headlights keep going up and down. Like auto adjusting. What could be the cause of it ?
Too be honest I feel my lights are always too low, they are bright but don't light up enough of the road ahead. Ive not driven it in completely dark places yet to see if it rises and turns full beams on as its adaptive lights.
Is there a way to raise or lower the beams?
Pass!
Any codes in VCDS? Not sure if you can do an output test??
I assume this is new and it's not always done it?? i.e. You don't have adaptive headlights??
Mine are not adaptive lights as far as I know. No fault in vcds
Mine are similar too low on road. I think we need to activate setting in vcds before adjusting headlights and than save through it.
With 333bhp I'm in need of better stopping power.
What's the biggest discs I can get with standard setup?
Looking at eurocarparts (30% promotion) I got few different sizes to choose from
320 or 356 front?
300 or 330 0r 356 rear?
Not looked but do the biTDI have bigger discs than normal? as even with 370bhp the brakes have great stopping power and are so sharp, sometimes too sharp that even I startle myself haha
