19x9 fitment on a 8P A3?
jlawie Apr 25, 2012
  1. jlawie
    jlawie Member
    Right O! Looking to do something a little different with my new car and have some ideas in the pipeline.
    From what I can tell, 19x9 will fit with no issues on the rear....but that about the front?
    Anyone got any pics of these size and can provide pics and details of offset?
    No need for comments regarding practicality or looks.....just wanna know if its been done etc etc.:blahblah1:
  2. FranA3
    FranA3 FMDETAILING Site Sponsor Regional Rep Gold Supporter Team Brill Red Audi A3
    7,265
    365
    everything depends on the offset of the wheels buddy , as you would more than likely need a spacer up front to clear the strutt and a spacer on the rear for the stance , its been done loads and loads of times matey so they will 100% fit but as i said depends on the offset , what wheels are they ??
  3. moag
    moag she's no d-turbo
    821
    35
    As fran said, its 100% dependant on offset and tyre choice. I have 19x9 on the rear and they are fine, pretty sure 9" on the front would be grand too
  4. jlawie
    jlawie Member
    Offsets have yet to be sorted out. Kinda hoping to get some recommended offsets from you guys.
  5. rob_watti
    rob_watti Member
    62
    what about 19" x 9 et52? should this be ok with a 225 tyre?
  6. FranA3
    7,265
    365
    you would be needing a spacer to clear the strutt with that mate
  7. N8
    17,163
    720
    You'll need to go 10mm all round, depends on what ride height you want as well.
  8. rob_watti
    rob_watti Member
    62
    ok i'll keep looking for some 8.5 speedlines. i'm not looking to run really low. maybe just a 20mm drop.
  9. rob_watti
    rob_watti Member
    62
    what about 8.5j et45 on the front and 9j et41 on the rear both with 225 tyres?
  10. moag
    821
    35
    That will be fine. I have a very similar set up on my car
  11. rob_watti
    rob_watti Member
    62
    Just going back to this I've managed to secure the above spec wheels but with only 1 good 225/35r19 tyre.
    Am I best with the wider wheels to the front or the back? I see that RS3 can be spec'd with wider front wheels and 245 tyres. Would I be better doing something similar with my set up?
    Rob
  12. KemiksiZ
    KemiksiZ Active Member
    570
    142
    43
    Chwck my ride, I have 225-40-18 with et 35, 9 rims rear..
    Front et35 with 9 rim is too wide.. I tried already :)
  13. moag
    821
    35
    Wider wheel on the back for sure.
    I'd put 225s on the 9" wheels and 215s on the 8.5s
  14. rob_watti
    rob_watti Member
    62
    ok cool that's what I thought. Just wondered why rs3's could have 245 as an option on the front. Thought they might be more room.
  15. poli84
    poli84 Member
    425
    57
    RS3's have slightly pumped out front guards to accomodate the wider tyres.
